Supprimer pup optional [résolu]
Re: Supprimer pup optional [résolu]
Mais c'est juste, un dossier, suffit de le supprimer.
C'est un logiciel que tu as utilisé qui le détecte ? style MBAM ?
Faudrait expliquer.
Eventuellement, faire cette correction pour supprimer des restes :
Start:
CloseProcesses:
CreateRestorePoint:
HKLM\SOFTWARE\Policies\Mozilla\Firefox: Restriction <==== ATTENTION
Task: {575BC741-EF55-4C94-B159-FBFD4B117B7E} - System32\Tasks\Opera scheduled Autoupdate 1732379897 => C:\Users\Lysie\AppData\Local\Programs\Opera\autoupdate\opera_autoupdate.exe  --scheduledtask --bypasslauncher $(Arg0) (Pas de fichier)
C:\Users\Lysie\AppData\Local\Google\Chrome\User Data\Default\Extensions\fheoggkfdfchfphceeifdbepaooicaho
Task: {5701F69E-AF00-40DF-8458-58E7248F7842} - System32\Tasks\CCleaner Update => C:\Program Files\CCleaner\CCUpdate.exe  (Pas de fichier)
Task: {157028D7-03A8-44E8-8BFE-69EEC5E11805} - System32\Tasks\CLToast => C:\Program Files (x86)\CyberLink\Shared files\CLToast.exe [2084872 2025-01-23] (CyberLink Corp. -> )
Task: {C7E9FC1B-3445-42FA-9A39-0D82B36CFDBF} - System32\Tasks\CLToastForceRun => C:\Program Files (x86)\CyberLink\Shared files\CLToast.exe [2084872 2025-01-23] (CyberLink Corp. -> )
Task: {9A7152DC-2957-4E8B-AA00-2CCC80979D0E} - System32\Tasks\CLToastRun => C:\Program Files (x86)\CyberLink\Shared files\CLToast.exe [2084872 2025-01-23] (CyberLink Corp. -> )
2025-03-27 15:15 - 2025-03-27 15:16 - 000000000 ___RD C:\Users\Lysie\AppData\Local\PCHealthCheck
2025-03-27 15:15 - 2025-03-27 15:15 - 000001360 _____ C:\Users\Lysie\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PC Health Check.lnk
2025-03-27 12:21 - 2025-04-04 19:06 - 000001304 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CyberLink Notification Center.lnk
2025-03-27 12:21 - 2025-03-27 12:21 - 000000000 ____D C:\Users\Public\CyberLink
2025-03-27 11:54 - 2025-03-27 11:54 - 000003936 _____ C:\WINDOWS\system32\Tasks\CCleaner Update
2025-03-27 11:53 - 2025-03-27 11:53 - 087988576 _____ (Gen Digital Inc.) C:\Users\Lysie\Downloads\ccsetup634.exe
2025-04-08 20:51 - 2024-12-31 18:14 - 000000000 ____D C:\Users\Lysie\AppData\Roaming\ZHP
2025-04-08 20:29 - 2024-11-08 16:09 - 000000130 _____ C:\Users\Lysie\AppData\LocalLow\3a4363af1cdcffbfd28a96af66bdca1f77df0c7f526d17325fa6f8b4a5fd0804
2025-04-08 20:23 - 2024-11-08 16:09 - 000054667 _____ C:\Users\Lysie\AppData\LocalLow\b31420a0ae1c721b6fcb507232ee476185a52e39b71e39c28b4362754997f72e
2025-04-08 18:37 - 2023-08-01 16:23 - 000000000 ____D C:\Users\Lysie\AppData\Local\D3DSCache
2025-04-07 21:26 - 2024-08-28 10:00 - 000043382 _____ C:\Users\Lysie\AppData\LocalLow\7bb658ca9d3e0a8269cc23c6c952563daa4af97e559b8417a0b1e84ca54a1b57
2025-04-07 21:26 - 2024-08-28 10:00 - 000000130 _____ C:\Users\Lysie\AppData\LocalLow\8912866bc396e4d2e262d43e2ac11b13d28a4ac46a8de62fb09abb91ebb6fb66
2025-04-07 20:19 - 2024-11-01 19:02 - 000031432 _____ C:\Users\Lysie\AppData\LocalLow\838da9a9bd8af666323235f7637c83cf42ed5fb068f1339518517dc25328f5f9
2025-04-07 17:18 - 2024-11-13 17:44 - 000198554 _____ C:\Users\Lysie\AppData\LocalLow\6d2564784232fcce046c9c0ac6e7a9fbfb7fe7afeffdbbf713855257aeb77227
2025-04-05 17:47 - 2024-08-28 19:21 - 000406235 _____ C:\Users\Lysie\AppData\LocalLow\5cc54e3c136bf04073e6d292e9fb13403159501abc2887169597cfda5cb1577a
2025-04-05 17:47 - 2024-08-28 19:21 - 000000130 _____ C:\Users\Lysie\AppData\LocalLow\98da6908e38292deda684a800ba47373d1860cd37e871d8e5a061a3450020972
2025-03-28 18:00 - 2024-09-16 12:30 - 000099026 _____ C:\Users\Lysie\AppData\LocalLow\ebe9d4f859ba3745b7e537cd883652000833b37710bb51a8f300193ccf70455a
2025-03-28 18:00 - 2024-09-16 12:30 - 000000130 _____ C:\Users\Lysie\AppData\LocalLow\9b9a0b5487e8a1a7461d4cc5197956403143b8a97b9fe29b416f1804d78859fb
2025-03-27 12:22 - 2024-05-10 19:25 - 000000000 ____D C:\Users\Lysie\AppData\Roaming\CyberLink
2025-03-27 12:21 - 2024-05-10 19:23 - 000000000 ___HD C:\ProgramData\CyberLink
C:\Users\Lysie\AppData\EPISoftware
Hosts:
EmptyTemp:
RemoveProxy:
Reboot:
End:
Redémarre l'ordinateur.
Important :
Le contenu de la correction ne doit pas être vide et doit refléter le script donné précédemment.
Dans le cas où la correction est vide, essaye de faire la correction FRST comme ceci :
Place le programme FRST sur le bureau
Ouvre le bloc-note.
Colle le script donné plus haut.
Enregistre le fichier sur le sur le bureau de Windows (pas ailleurs) sous le nom de fixlist.txt.
Relance FRST puis Corriger.
C'est quoi ce CCleaner que tu as installé ?
Si tu veux un programme en lien avec le nettoyage de la vie privée je conseille PRIVAZER
https://www.malekal.com/privazer-nettoyer-windows/
Il a été demandé de sécuriser le PC
RIEN n'a été fait (modules complémentaires comme Ublock Origin par ex)
Vu que tu télécharges pas mal de .pdf il faut aussi installer hardentools comme déjà indiqué
En plus tu as un comportement à risques (par méconnaissance en fait mais c'est normal)
Le EpiBrowser, s'installe par le biais d'une fenetre "pop up" qui apparait sur l écran suite possiblement à la visite d'un site internet foireux, où tu as possiblement téléchargé quelque chose (mais pas que)
Ca vient surtout a priori avec les programmes de retouches photos
Malekal s'en occupera
Edit : Il est passé AVANT moi donc tu suis ce qu'il a indiqué en priorité
Chrome est toujours utilisé mais tu as téléchargé Vivaldi sans l'installer
Si il peut paraitre un peu trop complexe, tu as SLIMJET
https://www.slimjet.com/fr/
dany65320
par dany65320 »
voilà voilà merci encore de m aider je vais de suite voir Parisien_entraide
et suivre ses conseils
https://pjjoint.malekal.com/files.php?r ... 98i13p15b7
Dans ton rapport :
"C:\Users\Lysie\AppData\EPISoftware" => non trouvé(e)
Le dossier n'existe pas.
Donc ma question à nouveau, pourquoi tu reviens ici pour parler de ce dossier ? Tu l'as vu en faisant une analyse avec un logiciel, MBAM ?
dany65320
par dany65320 »
j avais fait ce matin une nouvelle demande mais j ai pas retrouvée donc j ai mis ici
desolée je suis confuse je vais ouvrir une nouvelle demande
dany65320
par dany65320 »
Me revoici et encorde désolée de vous embeter
je met les liens
https://pjjoint.malekal.com/files.php?r ... q9r11f7q12
https://pjjoint.malekal.com/files.php?r ... 5b7t8d6z15
https://pjjoint.malekal.com/files.php?r ... 0z9e15w8q9
merci encore
Pour Parisien-entraide j ai cherché partout ccleaner et vivaldi mais je trouve rien
j ai aussi telecharger vos recommandations
slimjet et PrivaZer_free
Malekal a viré la tache de ccleaner avec le fichier téléchargé dans son dernier "fix", donc.. c'est normal :-)
Du coup ?
Malekal_morte a écrit : 09 avr. 2025 13:48 Dans ton rapport :
dany65320
par dany65320 »
bonsoir Parisien_entraide
du coup voici après je vous demande de m excuser j ai 70 ans et seule merci encore de votre aide et Malekal_morte
https://pjjoint.malekal.com/files.php?r ... z15o7h7i10
En fait MALEKAL te pose la question de savoir si "EPISoftware" est apparu lors d'une analyse de MalwareBytes (MBAM) puisque tu l'as téléchargé et installé
MBAM fournit un rapport, il faut donc le relancer pour le trouver
dany65320
par dany65320 »
oui oui j ai trouvé ça sur MalwareBytes
https://pjjoint.malekal.com/files.php?r ... 12o11z6j14
https://pjjoint.malekal.com/files.php?r ... 14k6h15v12
https://pjjoint.malekal.com/files.php?r ... 2v10g15c13
encore une fois j ai fait comme j ai pu
bonne soirée à vous tous et merci à vous deux
C'était dans la corbeille Windows :
Fichier: 1
PUP.Optional.EpiBrowser, C:\$RECYCLE.BIN\S-1-5-21-1159511470-3384442959-3141915671-1001\$RXKJANG.MSI, En quarantaine, 10209, 1300917, 1.0.97855, , ame, , BB85E632B76F0ABD230DA2D4D5D2D2C2, 6CCD43C1E3AADCD82323D92A74D4843FA2EB58963E6218B9BE63F04CCE12EB91
Encore des restes donc, pas de quoi s'alarmer, tout va bien !
