Problème installation malwarebyte3
Contact :
Re: Problème installation malwarebyte3
Message par Malekal_morte »
C'est un Windows XP, ce n'est plus supporté et je ne suis pas certains que MBAM fonctionne encore sur Windows XP.
CreateRestorePoint:
CloseProcesses:
Task: C:\WINDOWS\Tasks\CIS_{81EFDD93-DBBE-415B-BE6E-49B9664E3E82}.job => C:\DOCUME~1\AJD9B9~1.SPX\LOCALS~1\Temp\cis2C.exe <==== ATTENTION
HKLM Group Policy restriction on software: %SystemRoot%\at*.job <==== ATTENTION
HKLM Group Policy restriction on software: %SystemRoot%\Tasks\at*.job <==== ATTENTION
HKLM Group Policy restriction on software: at*.job <==== ATTENTION
HKLM Group Policy restriction on software: autorun.inf <==== ATTENTION
HKLM Group Policy restriction on software: %SystemRoot%\System32\at*.job <==== ATTENTION
HKU\S-1-5-21-1563377602-1595827855-1542849698-26081 Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRoot% <==== ATTENTION
HKU\S-1-5-21-1563377602-1595827855-1542849698-26081 Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRoot%*.exe <==== ATTENTION
HKU\S-1-5-21-1563377602-1595827855-1542849698-26081 Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRoot%System32\*.exe <==== ATTENTION
HKU\S-1-5-21-1563377602-1595827855-1542849698-26081 Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ProgramFilesDir% <==== ATTENTION
AppInit_DLLs: c:\progra~1\magnipic\sprote~1.dll => Pas de fichier
2010-09-16 16:00 - 2009-10-02 10:46 - 000083232 ____C (Trend Micro Inc.) C:\Documents and Settings\aj.SPXMLU\ipxfer.exe
2010-09-16 15:49 - 2009-10-02 10:39 - 000234536 ____C (Sysinternals - www.sysinternals.com) C:\Documents and Settings\aj.SPXMLU\psexec.exe
Task: C:\WINDOWS\Tasks\COMODO CMC {06A09C0F-DD9C-4191-A670-71115CD78627}.job => C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe
Task: C:\WINDOWS\Tasks\COMODO Signature Update {B9D5C6F9-17D2-4917-8BD0-614BAA1C6A59}.job => C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe
Task: C:\WINDOWS\Tasks\COMODO Telemetry {18AD3DFA-30C0-4B5F-84F7-F1870B1A4921}.job => C:\Program Files\COMODO\COMODO Internet Security\cis.exe
Task: C:\WINDOWS\Tasks\COMODO Update {A6D52E4F-569B-4756-B3D8-DF217313DA85}.job => C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe
EmptyTemp:
RemoveProxy:
Reboot:
Redémarre l'ordinateur.
monofinscubadiver
Message par monofinscubadiver »
Bonjour et désolé de ma réponse tardive, j'ai du trouver un autre ordi car l'ordi que l'on traite ne se connecte plus à internet. Firefox se lance, le réseau est bon, mais impossible d'ouvrir autre chose que la page de démarrage
J'ai fait point par point ce que tu m'as conseillé. le fichier Fixlog.txt n'est pas apparu sur le bureau à la réouverture, mais seulement quand j'ai fait la recherche, qui ne m'a donné comme résulat que "search.txt" alors que "fixlog.txt" venait d'apparaitre sur le bureau. Je te copie ci après le rapport. Merci par avance si tu peux m'aider à débloquer la situation, cordialement, Alex
Résultats de correction de Farbar Recovery Scan Tool (x86) Version: 23.09.2018
Exécuté par aj (30-09-2018 21:47:13) Run:1
Exécuté depuis C:\Documents and Settings\aj.SPXMLU\Bureau
Profils chargés: aj (Profils disponibles: aj & admin)
Mode d'amorçage: Normal
fixlist contenu:
CreateRestorePoint:
CloseProcesses:
EmptyTemp:
RemoveProxy:
Reboot:
Processus fermé avec succès.
C:\WINDOWS\Tasks\CIS_{81EFDD93-DBBE-415B-BE6E-49B9664E3E82}.job => déplacé(es) avec succès
HKLM Group Policy restriction on software: %SystemRoot%\at*.job <==== ATTENTION => restauré(es) avec succès
HKLM Group Policy restriction on software: %SystemRoot%\Tasks\at*.job <==== ATTENTION => restauré(es) avec succès
HKLM Group Policy restriction on software: at*.job <==== ATTENTION => restauré(es) avec succès
HKLM Group Policy restriction on software: autorun.inf <==== ATTENTION => restauré(es) avec succès
HKLM Group Policy restriction on software: %SystemRoot%\System32\at*.job <==== ATTENTION => restauré(es) avec succès
HKU\S-1-5-21-1563377602-1595827855-1542849698-26081 Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRoot% <==== ATTENTION => restauré(es) avec succès
HKU\S-1-5-21-1563377602-1595827855-1542849698-26081 Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRoot%*.exe <==== ATTENTION => restauré(es) avec succès
HKU\S-1-5-21-1563377602-1595827855-1542849698-26081 Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRoot%System32\*.exe <==== ATTENTION => restauré(es) avec succès
HKU\S-1-5-21-1563377602-1595827855-1542849698-26081 Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ProgramFilesDir% <==== ATTENTION => restauré(es) avec succès
"c:\progra~1\magnipic\sprote~1.dll" => Données de la valeur supprimé(es) avec succès
C:\Documents and Settings\aj.SPXMLU\ipxfer.exe => déplacé(es) avec succès
C:\Documents and Settings\aj.SPXMLU\psexec.exe => déplacé(es) avec succès
C:\WINDOWS\Tasks\COMODO CMC {06A09C0F-DD9C-4191-A670-71115CD78627}.job => déplacé(es) avec succès
C:\WINDOWS\Tasks\COMODO Signature Update {B9D5C6F9-17D2-4917-8BD0-614BAA1C6A59}.job => déplacé(es) avec succès
C:\WINDOWS\Tasks\COMODO Telemetry {18AD3DFA-30C0-4B5F-84F7-F1870B1A4921}.job => déplacé(es) avec succès
C:\WINDOWS\Tasks\COMODO Update {A6D52E4F-569B-4756-B3D8-DF217313DA85}.job => déplacé(es) avec succès
"HKU\S-1-5-21-1563377602-1595827855-1542849698-26081\SOFTWARE\Policies\Microsoft\Internet Explorer" => supprimé(es) avec succès
"HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\DefaultConnectionSettings" => supprimé(es) avec succès
"HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\SavedLegacySettings" => supprimé(es) avec succès
"HKU\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\SavedLegacySettings" => supprimé(es) avec succès
"HKU\S-1-5-21-1563377602-1595827855-1542849698-26081\Software\Microsoft\Windows\CurrentVersion\Internet Settings\\ProxyEnable" => supprimé(es) avec succès
"HKU\S-1-5-21-1563377602-1595827855-1542849698-26081\Software\Microsoft\Windows\CurrentVersion\Internet Settings\\ProxyServer" => supprimé(es) avec succès
"HKU\S-1-5-21-1563377602-1595827855-1542849698-26081\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\DefaultConnectionSettings" => supprimé(es) avec succès
"HKU\S-1-5-21-1563377602-1595827855-1542849698-26081\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\SavedLegacySettings" => supprimé(es) avec succès
BITS transfer queue => 0 B
DOMStoree, IE Recovery, AppCache, Feeds Cache, Thumbcache => 61182 B
Java, Flash, Steam htmlcache => 16775 B
Windows/system/dllcache/drivers => 176258 B
Edge => 0 B
Chrome => 225706377 B
Firefox => 260464068 B
Opera => 0 B
Documents and Settings => 0 B
Default User.WINDOWS => 136530 B
All Users.WINDOWS => 0 B
systemprofile => 269033137 B
LocalService.AUTORITE NT => 100002 B
NetworkService.AUTORITE NT => 1167699 B
aj.SPXMLU => 451735 B
admin_af => 0 B
admin.SPXMLU.000 => 0 B
admin.NE-1009-6WVCP1J => 0 B
RecycleBin => 87966200 B
EmptyTemp: => 806.1 MB données temporaires supprimées.
Le système a dû redémarrer.
==== Fin de Fixlog 21:49:25 ====
Contact :
ok :/
Passe cet outil : viewtopic.php?t=46167
Tu coches tout et lance la correction.
monofinscubadiver
Rien à faire, j'ai essayé en sans erreur même combat... Petit été parce qu'il n'y a plus que Firefox ? Si c'est le cas, que préconises tu ?
Contact :
Internet Explorer parvient à se connecter à internet ?
Si oui c'est Firefox le problème, tu peux le réinitialiser : réparer Mozilla Firefox (premier paragraphe)
