AvastIP.dll, Windows 7 update, erreur 0XC0000005, etc.
GAUTIERPAULY
Re: AvastIP.dll, Windows 7 update, erreur 0XC0000005, etc.
par GAUTIERPAULY »
Les voila
il y a eu moins deux antivirus installés :(
AV: AVG Antivirus (Enabled - Up to date) {4FC75CA5-1654-5411-7CFB-1893D506BCF4}
AV: Antivirus Trend Micro OfficeScan (Enabled - Up to date) {1E5CB925-ABFC-68A9-91DC-4258BDE6C44A}
Désinstalle :
Agent Trend Micro OfficeScan
ByteFence Anti-Malware
McAfee WebAdvisor
La correction doit être effectué en mode sans échec :
CreateRestorePoint:
CloseProcesses:
HKLM\...\Run: [AVGUI.exe] => C:\Program Files\AVG\Antivirus\AvLaunch.exe [290064 2018-10-10] (AVG Technologies CZ, s.r.o.)
AVG Antivirus; C:\Program Files\AVG\Antivirus\AVGSvc.exe [325072 2018-10-10] (AVG Technologies CZ, s.r.o.)
avgbIDSAgent; C:\Program Files\AVG\Antivirus\x64\aswidsagenta.exe [8237160 2018-10-10] (AVG Technologies CZ, s.r.o.)
AvgWscReporter; C:\Program Files\AVG\Antivirus\wsc_proxy.exe [110048 2018-10-10] (AVG Technologies CZ, s.r.o.)
avgArPot; C:\Windows\System32\drivers\avgArPot.sys [201264 2018-10-10] (AVG Technologies CZ, s.r.o.)
avgbidsdriver; C:\Windows\System32\drivers\avgbidsdrivera.sys [230880 2018-10-10] (AVG Technologies CZ, s.r.o.)
R1 avgbidsdriver; C:\Windows\System32\drivers\avgbidsdrivera.sys [230880 2018-10-10] (AVG Technologies CZ, s.r.o.)
R0 avgbidsh; C:\Windows\System32\drivers\avgbidsha.sys [202296 2018-10-10] (AVG Technologies CZ, s.r.o.)
R0 avgblog; C:\Windows\System32\drivers\avgbloga.sys [346616 2018-10-10] (AVG Technologies CZ, s.r.o.)
R0 avgbuniv; C:\Windows\System32\drivers\avgbuniva.sys [59520 2018-10-10] (AVG Technologies CZ, s.r.o.)
R0 avgElam; C:\Windows\System32\drivers\avgElam.sys [15344 2018-10-10] (AVG Technologies CZ, s.r.o.)
S3 avgHwid; C:\Windows\System32\drivers\avgHwid.sys [46920 2018-10-10] (AVG Technologies CZ, s.r.o.)
R1 avgKbd; C:\Windows\System32\drivers\avgKbd.sys [42312 2018-10-10] (AVG Technologies CZ, s.r.o.)
R2 avgMonFlt; C:\Windows\System32\drivers\avgMonFlt.sys [163224 2018-10-10] (AVG Technologies CZ, s.r.o.)
R1 avgRdr; C:\Windows\System32\drivers\avgRdr2.sys [111816 2018-10-10] (AVG Technologies CZ, s.r.o.)
R0 avgRvrt; C:\Windows\System32\drivers\avgRvrt.sys [87968 2018-10-10] (AVG Technologies CZ, s.r.o.)
R1 avgSnx; C:\Windows\System32\drivers\avgSnx.sys [1028696 2018-10-10] (AVG Technologies CZ, s.r.o.)
R1 avgSP; C:\Windows\System32\drivers\avgSP.sys [467760 2018-10-10] (AVG Technologies CZ, s.r.o.)
R2 avgStm; C:\Windows\System32\drivers\avgStm.sys [208488 2018-10-10] (AVG Technologies CZ, s.r.o.)
R0 avgVmm; C:\Windows\System32\drivers\avgVmm.sys [380992 2018-10-10] (AVG Technologies CZ, s.r.o.)
2018-10-10 18:32 - 2018-10-10 18:32 - 000000000 ____D C:\Users\gaut.pauly\AppData\Roaming\AVG
2018-10-10 18:30 - 2018-10-10 18:31 - 000000000 ____D C:\Users\gaut.pauly\AppData\Local\AVG
2018-10-10 18:27 - 2018-10-10 18:28 - 000000000 ____D C:\Windows\System32\Tasks\AVG
2018-10-10 18:24 - 2018-10-10 18:23 - 001028696 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgSnx.sys
2018-10-10 18:24 - 2018-10-10 18:23 - 000467760 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgSP.sys
2018-10-10 18:24 - 2018-10-10 18:23 - 000380992 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgVmm.sys
2018-10-10 18:24 - 2018-10-10 18:23 - 000378640 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\avgBoot.exe
2018-10-10 18:24 - 2018-10-10 18:23 - 000208488 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgStm.sys
2018-10-10 18:24 - 2018-10-10 18:23 - 000201264 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgArPot.sys
2018-10-10 18:24 - 2018-10-10 18:23 - 000163224 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgMonFlt.sys
2018-10-10 18:24 - 2018-10-10 18:23 - 000111816 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgRdr2.sys
C:\Program Files\Common Files\AVG
C:\ProgramData\AVG
RemoveProxy:
Reboot:
Redémarre l'ordinateur.
GAUTIERPAULY
par GAUTIERPAULY »
je n'arrive pas à désinstallé Agent Trend Micro OfficeScan car il faut un mot de passe
Pas top tout ça
on peut essayer de le supprimer par FRST sinon...
Déjà la correction a fonctionné, tu peux donner le rapport ?
GAUTIERPAULY
par GAUTIERPAULY »
je n'ai pas fait la suite car je savais pas si je devait continué : (
Tu peux sans problème.
GAUTIERPAULY
par GAUTIERPAULY »
Le voila les application on l'air de remarcher mes mon clavier c'est arreter de fonctionné après que j'ai corriger je dois donc utilisé le clavier du "mode tablet". Peux-tu me dire comment le rémetre. Merci 🙂👍
ok bonne nouvelle =)
Du coup il faudrait refaire un scan FRST pour supprimer Trend-Micro.
Relance une analyse et donne FRST.txt et Addition.txt
GAUTIERPAULY
par GAUTIERPAULY »
en attendans t'aurais un truc pour mon clavier qui ne marche plus
comme ça non.
Une fois qu'on aura supprimer Trend-Micro, tu tenteras la mise à jour de Windows 10 en espérant que ça remette tout d'applomb.
GAUTIERPAULY
par GAUTIERPAULY »
voilà PDT_003
GAUTIERPAULY
par GAUTIERPAULY »
mais je suis déja sur windows 10
oui tu es sur Windows 10, mais il y a des niveaux de versions.
Il y a deux mises à jour annuelles.
Si cela intéresse, voir cet article : https://www.malekal.com/builds-de-windows-10/
Tu es en 1607 :
Platform: Windows 10 Pro Version 1607 14393.2214 (X64) Langue: Français (France)
La dernière version actuelle est la 1803 et encore on devrait être en 1809..
Tu as trois versions de retard.
Il faudrait faire cette correction FRST et si possible en mode sans échec comme tu as fait précédemment.
CreateRestorePoint:
CloseProcesses:
HKU\S-1-5-21-2290784042-2876946086-961634400-212415\...\Run: [Chromium] => c:\users\gaut.pauly\appdata\local\chromium\application\chrome.exe [4149760 2017-09-22] (The Chromium Authors)
HKU\S-1-5-21-2290784042-2876946086-961634400-212415\...\Run: [Web Companion] => C:\Program Files (x86)\Lavasoft\Web Companion\Application\WebCompanion.exe --minimize
GroupPolicy: Restriction - Chrome <==== ATTENTION
CHR HKLM\SOFTWARE\Policies\Google: Restriction <==== ATTENTION
HKU\S-1-5-21-2290784042-2876946086-961634400-212415\...\Run: [Discord] => C:\Users\gaut.pauly\AppData\Local\Discord\app-0.0.301\Discord.exe [57816920 2018-04-30] (Discord Inc.)
R2 PremierOpinion; C:\Program Files (x86)\PremierOpinion\pmservice.exe [169408 2018-07-30] (VoiceFive, Inc.) <==== ATTENTION
R3 TMBMServer; C:\Program Files (x86)\Trend Micro\BM\TMBMSRV.exe [487368 2018-05-07] (Trend Micro Inc.)
R3 tmccsf; C:\Program Files (x86)\Trend Micro\OfficeScan Client\CCSF\tmccsf.exe [1520104 2018-05-24] (Trend Micro Inc.)
R2 tmlisten; C:\Program Files (x86)\Trend Micro\OfficeScan Client\tmlisten.exe [5871944 2018-05-24] (Trend Micro Inc.)
S2 AVG Antivirus; "C:\Program Files\AVG\Antivirus\AVGSvc.exe" [X]
S3 avgbIDSAgent; "C:\Program Files\AVG\Antivirus\x64\aswidsagenta.exe" [X]
S3 AvgWscReporter; "C:\Program Files\AVG\Antivirus\wsc_proxy.exe" /runassvc [X]
R2 tmactmon; C:\Windows\system32\DRIVERS\tmactmon.sys [134232 2018-05-04] (Trend Micro Inc.)
R1 tmcomm; C:\Windows\system32\DRIVERS\tmcomm.sys [437400 2017-10-15] (Trend Micro Inc.)
R0 TMEBC; C:\Windows\System32\DRIVERS\TMEBC64.sys [72504 2016-04-21] (Trend Micro Inc.)
R3 tmeevw; C:\Windows\system32\DRIVERS\tmeevw.sys [143064 2017-04-25] (Trend Micro Inc.)
S0 tmel; C:\Windows\System32\DRIVERS\tmel.sys [39056 2015-06-23] (Trend Micro Inc.)
R2 tmevtmgr; C:\Windows\system32\DRIVERS\tmevtmgr.sys [97912 2018-05-04] (Trend Micro Inc.)
C:\Program Files (x86)\Trend Micro\OfficeScan Client\TmXPFlt.sys [396944 2017-10-24] (Trend Micro Inc.)
R2 TmPreFilter; C:\Program Files (x86)\Trend Micro\OfficeScan Client\TmPreFlt.sys [70288 2017-10-24] (Trend Micro Inc.)
R1 tmumh; C:\Windows\system32\DRIVERS\TMUMH.sys [115616 2018-04-27] (Trend Micro Inc.)
R3 tmusa; C:\Windows\system32\DRIVERS\tmusa.sys [132728 2018-01-22] (Trend Micro Inc.)
R2 VSApiNt; C:\Program Files (x86)\Trend Micro\OfficeScan Client\VSApiNt.sys [2788504 2017-10-24] (Trend Micro Inc.)
2018-10-10 17:25 - 2018-10-23 13:41 - 000003250 _____ C:\Windows\System32\Tasks\Antivirus Emergency Update
2018-10-10 17:25 - 2018-10-10 17:33 - 000000000 ____D C:\Users\gaut.pauly\AppData\Local\chromium
2018-10-10 17:24 - 2018-10-10 17:23 - 000087968 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgRvrt.sys
2018-10-10 17:24 - 2018-10-10 17:23 - 000046920 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgHwid.sys
2018-10-10 17:24 - 2018-10-10 17:23 - 000042312 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgKbd.sys
2018-10-10 17:24 - 2018-10-10 17:23 - 000015344 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgElam.sys
2018-10-10 17:24 - 2018-10-10 17:22 - 000346616 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgbloga.sys
2018-10-10 17:24 - 2018-10-10 17:22 - 000230880 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgbidsdrivera.sys
2018-10-10 17:24 - 2018-10-10 17:22 - 000202296 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgbidsha.sys
2018-10-10 17:24 - 2018-10-10 17:22 - 000059520 _____ (AVG Technologies CZ, s.r.o.) C:\Windows\system32\Drivers\avgbuniva.sys
2018-10-10 17:23 - 2018-10-10 17:28 - 000000000 ____D C:\Users\gaut.pauly\AppData\Local\{709046CC-5438-2A74-39A0-0F9C1DC8F304}
2018-10-10 17:22 - 2018-11-04 15:27 - 000000000 ____D C:\Program Files (x86)\PremierOpinion
Task: {0154750A-EA76-4B6E-8C71-C55A961C7D4C} - System32\Tasks\ByteFence => c:\program files\bytefence\ByteFence.exe <==== ATTENTION
RemoveProxy:
Reboot:
Refais un scan fRST et donne à nouveau les rapports.
GAUTIERPAULY
par GAUTIERPAULY »
je n'ai pas le temps de faire tout sa povez vous me dire comment remettre mon clavier pour les cour demain, et que demain je fasse réinitialisé tout le pc merci de me rep ite !!!😭😭😭😭😭😭😭😭😭😭😭😭😭😭😣😣😣😣😣😣😩😩😩😩😔😔😔😖😖😖😖😢😢😢😢😢
GAUTIERPAULY
par GAUTIERPAULY »
vite ite vite
