plusieurs problèmes!!!
Re: plusieurs problèmes!!!
par SkyTech »
Relance HijackThis (clic droit dessus, Exécuter en tant qu'administrateur), coche ces lignes en rouge et clic sur Fix checked.
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.google.fr/webhp?sourceid=na ... r&ie=UTF-8
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O2 - BHO: Programme d'aide de l'Assistant de connexion Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll (file missing)
O3 - Toolbar: uTorrentBar_FR Toolbar - {05eeb91a-aef7-4f8a-978f-fb83e7b03f8e} - C:\Program Files (x86)\uTorrentBar_FR\tbuTor.dll (file missing)
O3 - Toolbar: ZoneAlarm Security Engine - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll (file missing)
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [LWS] C:\Program Files (x86)\Logitech\LWS\Webcam Software\LWS.exe -hide
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [TkBellExe] "c:\program files (x86)\real\realplayer\Update\realsched.exe" -osboot
O4 - HKLM\..\Run: [APSDaemon] "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
O4 - HKCU\..\Run: [swg] "C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
O4 - Startup: Dropbox.lnk = ?
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~1\Office12\REFIEBAR.DLL
O9 - Extra button: (no name) - Cmdmapping - (no file) (HKCU)
O15 - Trusted Zone: http://*.mappy.com
O15 - Trusted Zone: http://*.orange.fr
O15 - Trusted Zone: http://rw.search.ke.voila.fr
O15 - Trusted Zone: http://orange.weborama.fr
O16 - DPF: {C345E174-3E87-4F41-A01C-B066A90A49B4} (WRC Class) - http://trial.trymicrosoftoffice.com/tri ... /wrc32.ocx
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/Me ... b56907.cab
Utilise cette astuce : http://forum.malekal.com/executer-dans- ... tml#p64205
Et :
Menu démarrer, exécuter, tape services.msc, entrée
Dans la fenêtre qui s'ouvre cherche :
Adobe Active File Monitor V7
Apple Mobile Device
ForceWare Intelligent Application Manager
Nero BackItUp Scheduler 4.0
ForceWare IP service
NVIDIA Update Service Daemon
RealNetworks Downloader Resolver Service
Skype Updater
NVIDIA Stereoscopic 3D Driver Service
Double clique dessus, dans type de démarrage mets manuel.
Mets celui-là en désactivé :
NVIDIA Display Driver Service
/!\ Désactive ton antivirus /!\
Télécharge OTM (de OldTimer). Sauvegarde-le sur ton Bureau.
Copie (Ctrl+C) le texte se situant dans le cadre ci-dessous :
:services
gupdate
gupdatem
gusvc
:files
C:\Program Files (x86)\Google\Update
C:\Program Files (x86)\Google\Common\Google Updater
:commands
[purity]
[emptytemp]
[emptyflash]
Double clique sur OTM.exe afin de le lancer.
Colle (ou Ctrl+V) le texte précédemment copié dans le cadre Paste Instructions for Items to be Moved.
Clique maintenant sur le bouton MoveIt! puis ferme OTM.
Si un fichier ou dossier ne peut pas être supprimé immédiatement, le logiciel te demandera de redémarrer.
Accepte en cliquant sur YES.
Poste le rapport situé dans ce dossier : C:\_OTM\MovedFiles\
Le nom du rapport correspond au moment de sa création : date_heure.log
Poste un nouveau rapport HijackThis.
