voila
ll processes killed
========== OTL ==========
No active process named Program Files was found!
No active process named upstv_fr_8.exe was found!
Error: Unable to stop service WebCakeUpdater!
Registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\WebCakeUpdater deleted successfully.
C:\Program Files (x86)\Web Cake\WebCakeDesktop.Updater.exe moved successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{647C0A03-BF74-C6F0-55E3-0FEAC94AFB67}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{647C0A03-BF74-C6F0-55E3-0FEAC94AFB67}\ not found.
64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{4E9B49A6-487D-738B-6FFE-3F8C963DB244}\ deleted successfully.
64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{4E9B49A6-487D-738B-6FFE-3F8C963DB244}\ not found.
64bit-Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\!{EEE6C35B-6118-11DC-9C72-001320C79847} deleted successfully.
64bit-Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\!{F9639E4A-801B-4843-AEE3-03D9DA199E77} deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\startertv_fr_8 deleted successfully.
C:\Program Files (x86)\startertv_fr_8\startertv_fr_8.exe moved successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunOnce\\upstv_fr_8.exe deleted successfully.
C:\Users\louis\AppData\Local\startertv_fr_8\upstv_fr_8.exe moved successfully.
C:\Users\louis\AppData\Local\eorezo\eorezo\1.10 folder moved successfully.
C:\Users\louis\AppData\Local\eorezo\eorezo folder moved successfully.
C:\Users\louis\AppData\Local\eorezo folder moved successfully.
C:\Users\louis\AppData\Roaming\Web Cake folder moved successfully.
C:\Program Files (x86)\Web Cake folder moved successfully.
C:\Users\louis\AppData\Local\Software\CrashReports folder moved successfully.
C:\Users\louis\AppData\Local\Software folder moved successfully.
C:\Users\louis\AppData\Local\startertv_fr_8\startertv_fr_8\1.10 folder moved successfully.
C:\Users\louis\AppData\Local\startertv_fr_8\startertv_fr_8 folder moved successfully.
C:\Users\louis\AppData\Local\startertv_fr_8\Download folder moved successfully.
C:\Users\louis\AppData\Local\startertv_fr_8 folder moved successfully.
C:\Program Files (x86)\startertv_fr_8 folder moved successfully.
[EMPTYTEMP]
User: All Users
User: Default
->Temporary Internet Files folder emptied: 0 bytes
User: Default User
User: louis
->Temp folder emptied: 3230399 bytes
->Temporary Internet Files folder emptied: 259849674 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 24424169 bytes
->Google Chrome cache emptied: 381135882 bytes
->Flash cache emptied: 3130 bytes
User: Public
%systemroot%\System32 (64bit) .tmp files removed: 0 bytes
Windows Temp folder emptied: 432167861 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 262 bytes
RecycleBin emptied: 8222939620 bytes
Total Files Cleaned = 8 892,00 mb
OTL by OldTimer - Version 3.2.69.0 log created on 08092013_172141
C:\Users\louis\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\ZMP42F2W\post349265[1].htm moved successfully.
C:\Users\louis\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\S26I5OCI\adsCAGCDOUE.htm moved successfully.
C:\Users\louis\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\S26I5OCI\afr[4].htm moved successfully.
C:\Users\louis\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\0HCVC74I\adsCA83MRSI.htm moved successfully.
C:\Users\louis\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\0AXMQ9RG\fastbutton[1].htm moved successfully.
C:\Users\louis\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\AntiPhishing\7A7E08C8-3FF5-45F2-873D-A84D669DC82F.dat moved successfully.
C:\Users\louis\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\MSIMGSIZ.DAT moved successfully.
C:\Users\louis\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
File\Folder C:\Windows\temp\~bd4056.tmp not found!
PendingFileRenameOperations files...
Registry entries deleted on Reboot..
qv06.com / page indesirable
Re: qv06.com / page indesirable
ça devrait etre ok , je pense .
TU confirmes !
zip c:\_OTL et envoie à Malekal comme demandé dans le message précedent.
TU confirmes !
Un p'tit Don à Angélique
Merci.
je dois partir sa a l'air d'aller je confirme demain
bonne soirée et merci a+ louis
bonjour
voila les 2 problèmes sont réglé grâce a Malekal et angélique ,
donc affaire résolu ,
a bientôt si d'autre problème
Pour ne plus te faire avoir.
A lire - Programmes parasites / PUPs : https://www.malekal.com/adwares-pup-protection/
salutMalekal_morte a écrit :![]()
merci pour le lien a+
dipadloks.com - page internet indésirable [résolu]
par matrix971 » » dans Windows : Résoudre les problèmes - 5 Réponses
- 104 Vues
Dernier message par angelique
