System Information (local)
computer name: VANESSA-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Pentium(R) CPU P6200 @ 2.13GHz Intel586, level: 6
2 logical processors, active mask: 3
RAM: 3949678592 total
VM: 2147352576, free: 1980973056
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sat 16/03/2013 21:29:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031613-26863-01.dmp
This was probably caused by the following module: igdkmd64.sys (igdkmd64+0x8BF0)
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA80081AE000)
Error: BUGCODE_USB_DRIVER
file path: C:\Windows\system32\drivers\igdkmd64.sys
product: Intel Graphics Accelerator Drivers for Windows 7(R)
company: Intel Corporation
description: Intel Graphics Kernel Mode Driver
Bug check description: This indicates that an error has occurred in a Universal Serial Bus (USB) driver.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: igdkmd64.sys (Intel Graphics Kernel Mode Driver, Intel Corporation).
Google query: Intel Corporation BUGCODE_USB_DRIVER
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: usbhub.sys (usbhub+0x12A60)
file path: C:\Windows\system32\drivers\usbhub.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Default Hub Driver for USB
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sun 10/03/2013 12:30:52 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031013-55349-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA80084CD000)
On Sun 10/03/2013 10:16:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031013-25225-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA8008155000)
On Sat 09/03/2013 21:19:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030913-26691-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA800813E000)
On Sat 09/03/2013 19:56:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030913-27814-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA80082F6000)
On Sat 09/03/2013 18:43:51 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030913-24133-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA8008168000)
On Sat 09/03/2013 12:37:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030913-35755-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA8008138000)
On Fri 08/03/2013 21:39:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030813-37377-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA8008052000)
On Fri 08/03/2013 20:48:29 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030813-32323-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA80080A0000)
On Fri 08/03/2013 20:45:39 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030813-32604-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA800821F000)
On Fri 08/03/2013 18:58:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030813-40950-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA8007FA2000)
On Wed 06/03/2013 21:42:36 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030613-38376-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA8008289000)
On Mon 04/03/2013 22:24:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030413-29187-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA80083E0000)
On Mon 04/03/2013 19:49:36 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030413-39234-01.dmp
Bugcheck code: 0xFE (0x8, 0x6, 0x5, 0xFFFFFA80081C6000)
Conclusion
17 crash dumps have been found and analyzed. Only 15 are included in this report. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Plantage écran et bug usb driver
Re: Plantage écran et bug usb driver
on me met ca sur touslesdrivers
Intel Pentium CPU P6200 @ 2.13GHz
Drivers installés:
Constructeur: | Fichier INF: cpu.inf | Classe: processor | Version: 6.1.7600.16385 | Date: 21/06/2006
Drivers installés:
Intel Corporation Intel HD Graphics
Drivers installés:
Constructeur: Intel Corporation | Fichier INF: oem20.inf | Classe: display | Version: 8.15.10.2993 | Date: 30/01/2013
Realtek Semiconductor Corp. Realtek High Definition Audio
Drivers installés:
Constructeur: Realtek Semiconductor Corp. | Fichier INF: oem13.inf | Classe: media | Version: 6.0.1.6141 | Date: 22/06/2010
Intel(R) Corporation Son Intel pour écrans
Drivers installés:
Constructeur: Intel(R) Corporation | Fichier INF: oem18.inf | Classe: media | Version: 6.14.0.3086 | Date: 23/08/2011
Broadcom NetLink (TM) Gigabit Ethernet
Drivers installés:
Constructeur: Broadcom | Fichier INF: oem4.inf | Classe: net | Version: 14.0.1.0 | Date: 15/05/2010
Drivers disponibles:
Broadcom NetLink BCM57xx K57 (drivers 15.4.0.9 WHQL)
Constructeur: Broadcom | Fichier INF: k57nd60a.inf | Classe: net | Version: 15.4.0.9 | Date: 25/08/2012 | Date de publication: 29/11/2012
Qualcomm Atheros Communications Inc. Qualcomm Atheros AR5B97 Wireless Network Adapter
Drivers installés:
Constructeur: Qualcomm Atheros Communications Inc. | Fichier INF: oem19.inf | Classe: net | Version: 10.0.0.221 | Date: 22/11/2012
Chicony Electronics Co., Ltd 1.3M HD WebCam
Drivers installés:
Constructeur: Chicony Electronics Co., Ltd | Fichier INF: usbvideo.inf | Classe: image | Version: 6.1.7601.17514 | Date: 21/06/2006
Intel Corporation Intel 5 Series 4 Port SATA AHCI Controller
Drivers installés:
Constructeur: Intel Corporation | Fichier INF: oem9.inf | Classe: hdc | Version: 11.7.0.1013 | Date: 19/11/2012
PIONEER DVD-RW DVRTD11RS SCSI CdRom Device
Drivers installés:
Constructeur: | Fichier INF: cdrom.inf | Classe: cdrom | Version: 6.1.7601.17514 | Date: 21/06/2006
ELAN PS/2 Port Input Device
Drivers installés:
Constructeur: ELAN | Fichier INF: oem14.inf | Classe: mouse | Version: 7.0.6.5 | Date: 13/04/2010
Standard PS/2 Keyboard
Drivers installés:
Constructeur: | Fichier INF: keyboard.inf | Classe: keyboard | Version: 6.1.7601.17514 | Date: 21/06/2006
Moniteur Plug-and-Play générique
Drivers installés:
Constructeur: | Fichier INF: monitor.inf | Classe: monitor | Version: 6.1.7600.16385 | Date: 21/06/2006
Intel processor DRAM Controller - 0044
Drivers installés:
Constructeur: Intel | Fichier INF: oem6.inf | Classe: system | Version: 9.1.1.1022 | Date: 28/10/2009
Intel Chipset Device Software (drivers 9.3.0.1026 WHQL)
Constructeur: Intel | Fichier INF: intelcp2.inf | Classe: system | Version: 9.1.9.1002 | Date: 05/10/2012 | Date de publication: 21/11/2012
Intel 82801 PCI Bridge - 2448
Drivers installés:
Constructeur: | Fichier INF: machine.inf | Classe: system | Version: 6.1.7601.17514 | Date: 21/06/2006
Intel QuickPath Architecture Generic Non-core Registers - 2C62
Drivers installés:
Intel QuickPath Architecture System Address Decoder - 2D01
Drivers installés:
Intel QPI Link 0 - 2D10
Drivers installés:
Intel QPI Physical 0 - 2D11
Drivers installés:
Intel Reserved - 2D12
Drivers installés:
Intel Reserved - 2D13
Drivers installés:
Intel HM55 Express Chipset LPC Interface Controller - 3B09
Drivers installés:
Intel 5 Series/3400 Series Chipset Family SMBus Controller - 3B30
Drivers installés:
Intel Turbo Boost Technology Driver
Drivers installés:
Constructeur: Intel | Fichier INF: oem10.inf | Classe: system | Version: 1.2.0.1002 | Date: 26/02/2010
Intel 5 Series/3400 Series Chipset Family PCI Express Root Port 1 - 3B42
Drivers installés:
Intel 5 Series/3400 Series Chipset Family PCI Express Root Port 2 - 3B44
Drivers installés:
High Definition Audio Controller
Drivers installés:
Constructeur: | Fichier INF: hdaudbus.inf | Classe: system | Version: 6.1.7601.17514 | Date: 19/11/2010
Intel Management Engine Interface
Drivers installés:
Constructeur: Intel | Fichier INF: oem7.inf | Classe: system | Version: 6.0.0.1179 | Date: 17/09/2009
Intel 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
Drivers installés:
Constructeur: Intel | Fichier INF: oem5.inf | Classe: usb | Version: 9.1.1.1020 | Date: 20/08/2009
Intel 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
Drivers installés:
Generic USB Hub
Drivers installés:
Constructeur: | Fichier INF: usb.inf | Classe: usb | Version: 6.1.7601.17586 | Date: 21/06/2006
Generic USB Hub
Drivers installés:
Chicony Electronics Co., Ltd Périphérique USB composite
Drivers installés:
Constructeur: Chicony Electronics Co., Ltd | Fichier INF: usb.inf | Classe: usb | Version: 6.1.7601.17586 | Date: 21/06/2006
que dois je faire? pourtant je les ai mis à jour
merci
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Drivers installés:
Generic USB Hub
Drivers installés:
Generic USB Hub
Drivers installés:
Drivers installés:
merci
Yop,
Comme aucun nouveau pilote n'est disponible, et que la cause est encore et toujours tes pilotes graphiques et USB, je te conseille de faire une restauration usine pour repartir sur des bases saines : http://forum.malekal.com/restauration-c ... 29605.html
bonsoir Skytech,
ok pour la restauration mais j'ai peur de tout perdre...
n'y a t il pas une autre solution plus simple? car après il faudra que je remette à jours tous les drivers non?
La restauration est en effet destructive.
Si tu n'as pas de problème non, on ne met à jour les pilotes qu'en cas de soucis.jvanessa1982 a écrit :car après il faudra que je remette à jours tous les drivers non?
C'est le dernier recours.jvanessa1982 a écrit :n'y a t il pas une autre solution plus simple?
- 2 Réponses
- 202 Vues
Dernier message par webangel
Bug permanent Crête d'alimentation sur le port usb
par lenagr » » dans Windows : Résoudre les problèmes - 12 Réponses
- 262 Vues
- 12 Réponses
- 309 Vues
- 150 Vues
- 212 Vues
