apache 2
Modérateur : Mods GNU/Linux
mgserv
par mgserv »
oui mais je tourne sur apache2 :mrgreen:
bon je v tourner sur apache c'est pas grave
quel ligne je dois modifier car ya bcp de truc dessus lol
Tjrs la variable DocumentRoot.
Pour apache :
/etc/apache/httpd.conf:DocumentRoot /var/www
Pour apache2 :
/etc/apache2/sites-available/default:   DocumentRoot /var/www/
mgserv
par mgserv »
merci !
mais dans le fichier httpd.conf je ne trouve pas de DocuementRoot PDT_014 le seul qui ya a un #devant et c pas trop la direction regarde ^^
#<VirtualHost ip.address.of.host.some_domain.com>
#    ServerAdmin [email protected]_domain.com
#    DocumentRoot /www/docs/host.some_domain.com
#    ServerName host.some_domain.com
#    ErrorLog logs/host.some_domain.com-error.log
#    CustomLog logs/host.some_domain.com-access.log common
#</VirtualHost>
désole je debute sous linux moi :s sinon voici tous ce kil y a dedans
<IfModule mod_alias.c>
    Alias /icons/ /usr/share/apache/icons/
    <Directory /usr/share/apache/icons>
         Options Indexes MultiViews
         AllowOverride None
         Order allow,deny
         Allow from all
    </Directory>
    Alias /images/ /usr/share/images/
    <Directory /usr/share/images>
         Options MultiViews
         AllowOverride None
         Order allow,deny
         Allow from all
    </Directory>
</IfModule>
# ScriptAlias: This controls which directories contain server scripts.
# ScriptAliases are essentially the same as Aliases, except that
# documents in the realname directory are treated as applications and
# run by the server when requested rather than as documents sent to the client.
# The same rules about trailing "/" apply to ScriptAlias directives as to
# Alias.
    ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
# "/usr/lib/cgi-bin" could be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
    <Directory /usr/lib/cgi-bin/>
        AllowOverride None
        Options ExecCGI -MultiViews +SymLinksIfOwnerMatch
        Order allow,deny
        Allow from all
    </Directory>
</IfModule>
# Redirect allows you to tell clients about documents which used to exist in
# your server's namespace, but do not anymore. This allows you to tell the
# clients where to look for the relocated document.
# Format: Redirect old-URI new-URL
# Directives controlling the display of server-generated directory listings.
<IfModule mod_autoindex.c>
    # FancyIndexing: whether you want fancy directory indexing or standard
    IndexOptions FancyIndexing NameWidth=*
    # AddIcon* directives tell the server which icon to show for different
    # files or filename extensions.  These are only displayed for
    # FancyIndexed directories.
    AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
    AddIconByType (TXT,/icons/text.gif) text/*
    AddIconByType (IMG,/icons/image2.gif) image/*
    AddIconByType (SND,/icons/sound2.gif) audio/*
    AddIconByType (VID,/icons/movie.gif) video/*
    AddIcon /icons/binary.gif .bin .exe
    AddIcon /icons/binhex.gif .hqx
    AddIcon /icons/tar.gif .tar
    AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
    AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
    AddIcon /icons/a.gif .ps .ai .eps
    AddIcon /icons/layout.gif .html .shtml .htm .pdf
    AddIcon /icons/text.gif .txt
    AddIcon /icons/c.gif .c
    AddIcon /icons/p.gif .pl .py
    AddIcon /icons/f.gif .for
    AddIcon /icons/dvi.gif .dvi
    AddIcon /icons/uuencoded.gif .uu
    AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
    AddIcon /icons/tex.gif .tex
    AddIcon /icons/bomb.gif core
    AddIcon /icons/deb.gif .deb
    AddIcon /icons/back.gif ..
    AddIcon /icons/hand.right.gif README
    AddIcon /icons/folder.gif ^^DIRECTORY^^
    AddIcon /icons/blank.gif ^^BLANKICON^^
    # DefaultIcon: which icon to show for files which do not have an icon
    # explicitly set.
    DefaultIcon /icons/unknown.gif
    # AddDescription: allows you to place a short description after a file in
    # server-generated indexes.  These are only displayed for FancyIndexed
    # directories.
    # Format: AddDescription "description" filename
    #AddDescription "GZIP compressed document" .gz
    #AddDescription "tar archive" .tar
    #AddDescription "GZIP compressed tar archive" .tgz
    # ReadmeName: the name of the README file the server will look for by
    # default, and append to directory listings.
    # HeaderName: the name of a file which should be prepended to
    # directory indexes.
    # The module recognize only 2 kind of mime-types, text/html and
    # text/*, but the only method it has to identify them is via
    # the filename extension. The default is to include and display
    # html files.
    ReadmeName README.html
    HeaderName HEADER.html
    # Otherwise you can comment the 2 lines above and uncomment
    # the 2 below in order to display plain text files.
    # ReadmeName README.txt
    # HeaderName HEADER.txt
    # IndexIgnore: a set of filenames which directory indexing should ignore
    # and not include in the listing.  Shell-style wildcarding is permitted.
    IndexIgnore .??* *~ *# HEADER.html HEADER.txt RCS CVS *,v *,t
    # Uncomment the following IndexIgnore line to add README.* to the file
    # list that will not be displayed by mod_autoindex.
    # It is not enabled by default on Debian system to permit users to properly
    # browse Debian documentation (/doc/)
    #IndexIgnore README.*
</IfModule>
# Document types.
<IfModule mod_mime.c>
    # AddEncoding allows you to have certain browsers (Mosaic/X 2.1+)
    # uncompress information on the fly. Note: Not all browsers support
    # this.  Despite the name similarity, the following Add* directives
    # have nothing to do with the FancyIndexing customization
    # directives above.
    AddEncoding x-compress Z
    AddEncoding x-gzip gz tgz
    # AddLanguage: allows you to specify the language of a document. You can
    # then use content negotiation to give a browser a file in a language
    # it can understand.
    # Note 1: The suffix does not have to be the same as the language
    # keyword --- those with documents in Polish (whose net-standard
    # language code is pl) may wish to use "AddLanguage pl .po" to
    # avoid the ambiguity with the common suffix for perl scripts.
    # Note 2: The example entries below illustrate that in quite
    # some cases the two character 'Language' abbriviation is not
    # identical to the two character 'Country' code for its country,
    # E.g. 'Danmark/dk' versus 'Danish/da'.
    # Note 3: There is 'work in progress' to fix this and get
    # the reference data for rfc3066 cleaned up.
    # Danish (da) - Dutch (nl) - English (en) - Estonian (ee)
    # French (fr) - German (de) - Greek-Modern (el)
    # Italian (it) - Portugese (pt) - Luxembourgeois (lb)
    # Spanish (es) - Swedish (sv) - Catalan (ca) - Czech(cs)
    # Polish (pl) - Brazilian Portuguese (pt-br) - Japanese (ja)
    AddLanguage da .dk
    AddLanguage nl .nl
    AddLanguage en .en
    AddLanguage et .ee
    AddLanguage fr .fr
    AddLanguage de .de
    AddLanguage el .el
    AddLanguage it .it
    AddLanguage ja .ja
    AddCharset ISO-2022-JP .jis
    AddLanguage pl .po
    AddCharset ISO-8859-2 .iso-pl
    AddLanguage pt .pt
    AddLanguage pt-br .pt-br
    AddLanguage lb .lu
    AddLanguage ca .ca
    AddLanguage es .es
    AddLanguage sv .se
    AddLanguage cs .cz
    # LanguagePriority: allows you to give precedence to some languages
    # in case of a tie during content negotiation.
    # Just list the languages in decreasing order of preference. We have
    # more or less alphabetized them here. You probably want to change
    # this.
    <IfModule mod_negotiation.c>
        LanguagePriority en da nl et fr de el it ja pl pt pt-br lb ca es sv
    </IfModule>
    # AddType allows you to tweak mime.types without actually editing
    # it, or to make certain files to be certain types.
    # For example, the PHP 3.x module (not part of the Apache
    # distribution - see http://www.php.net) will typically use:
    #AddType application/x-httpd-php3 .php3
    #AddType application/x-httpd-php3-source .phps
    # And for PHP 4.x, use:
    #AddType application/x-httpd-php .php
    #AddType application/x-httpd-php-source .phps
    AddType application/x-tar .tgz
    AddType image/bmp .bmp
    # hdml
    AddType text/x-hdml .hdml
    # AddHandler allows you to map certain file extensions to "handlers",
    # actions unrelated to filetype. These can be either built into
    # the server or added with the Action command (see below).
    # If you want to use server side includes, or CGI outside
    # ScriptAliased directories, uncomment the following lines.
    # To use CGI scripts:
    #AddHandler cgi-script .cgi .sh .pl
    # To use server-parsed HTML files mod_include has to be enabled.
    <IfModule mod_include.c>
     AddType text/html .shtml
     AddHandler server-parsed .shtml
    </IfModule>
    # Uncomment the following line to enable Apache's send-asis HTTP
    # file feature.
    #AddHandler send-as-is asis
    # If you wish to use server-parsed imagemap files, use
    #AddHandler imap-file map
    # To enable type maps, you might want to use
    #AddHandler type-map var
</IfModule>
# End of document types.
# Default charset to iso-8859-1 (http://www.apache.org/info/css-security/).
AddDefaultCharset on
# Action: lets you define media types that will execute a script whenever
# a matching file is called. This eliminates the need for repeated URL
# pathnames for oft-used CGI file processors.
# Format: Action media/type /cgi-script/location
# Format: Action handler-name /cgi-script/location
# MetaDir: specifies the name of the directory in which Apache can find
# meta information files. These files contain additional HTTP headers
# to include when sending the document
#MetaDir .web
# MetaSuffix: specifies the file name suffix for the file containing the
# meta information.
#MetaSuffix .meta
# Customizable error response (Apache style)
#  these come in three flavors
#    1) plain text
#ErrorDocument 500 "The server made a boo boo.
#  n.b.  the (") marks it as text, it does not get output
#    2) local redirects
#ErrorDocument 404 /missing.html
#  to redirect to local URL /missing.html
#ErrorDocument 404 /cgi-bin/missing_handler.pl
#  N.B.: You can redirect to a script or a document using server-side-includes.
#    3) external redirects
#ErrorDocument 402 http://some.other_server.com/subscription_info.html
#  N.B.: Many of the environment variables associated with the original
#  request will *not* be available to such a script.
<IfModule mod_setenvif.c>
    # The following directives modify normal HTTP response behavior.
    # The first directive disables keepalive for Netscape 2.x and browsers that
    # spoof it. There are known problems with these browser implementations.
    # The second directive is for Microsoft Internet Explorer 4.0b2
    # which has a broken HTTP/1.1 implementation and does not properly
    # support keepalive when it is used on 301 or 302 (redirect) responses.
    BrowserMatch "Mozilla/2" nokeepalive
    BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
    # The following directive disables HTTP/1.1 responses to browsers which
    # are in violation of the HTTP/1.0 spec by not being able to grok a
    # basic 1.1 response.
    BrowserMatch "RealPlayer 4\.0" force-response-1.0
    BrowserMatch "Java/1\.0" force-response-1.0
    BrowserMatch "JDK/1\.0" force-response-1.0
</IfModule>
# If the perl module is installed, this will be enabled.
<IfModule mod_perl.c>
   Alias /perl/ /var/www/perl/
  </IfModule>
  <Location /perl>
    SetHandler perl-script
    PerlHandler Apache::Registry
    Options +ExecCGI
  </Location>
</IfModule>
# Allow http put (such as Netscape Gold's publish feature)
# Use htpasswd to generate /etc/apache/passwd.
# You must unremark these two lines at the top of this file as well:
#LoadModule put_module          modules/mod_put.so
#AddModule mod_put.c
#<IfModule mod_alias.c>
# Alias /upload /tmp
#</IfModule>
#<Location /upload>
#    EnablePut On
#    AuthType Basic
#    AuthName Temporary
#    AuthUserFile /etc/apache/passwd
#    EnableDelete Off
#    umask 007
#    <Limit PUT>
#       require valid-user
#    </Limit>
#</Location>
# Allow server status reports, with the URL of http://servername/server-status
# Change the ".your_domain.com" to match your domain to enable.
#<Location /server-status>
#    SetHandler server-status
#    Order deny,allow
#    Deny from all
#    Allow from .your_domain.com
#</Location>
# Allow remote server configuration reports, with the URL of
#  http://servername/server-info (requires that mod_info.c be loaded).
#<Location /server-info>
#    SetHandler server-info
#    Order deny,allow
#    Deny from all
#</Location>
# Allow access to local system documentation from localhost.
# (Debian Policy assumes /usr/share/doc is "/doc/", at least from the localhost.)
 Alias /doc/ /usr/share/doc/
</IfModule>
<Location /doc>
  order deny,allow
  deny from all
  allow from 127.0.0.0/255.0.0.0
  Options Indexes FollowSymLinks MultiViews
</Location>
# There have been reports of people trying to abuse an old bug from pre-1.1
# days.  This bug involved a CGI script distributed as a part of Apache.
# By uncommenting these lines you can redirect these attacks to a logging
# script on phf.apache.org.  Or, you can record them yourself, using the script
# support/phf_abuse_log.cgi.
#<Location /cgi-bin/phf*>
#    Deny from all
#    ErrorDocument 403 http://phf.apache.org/phf_abuse_log.cgi
#</Location>
<IfModule mod_proxy.c>
    # Proxy Server directives. Uncomment the following lines to
    # enable the proxy server:
    #ProxyRequests On
    #<Directory proxy:*>
    #    Order deny,allow
    #    Deny from all
    #</Directory>
    # Enable/disable the handling of HTTP/1.1 "Via:" headers.
    # ("Full" adds the server version; "Block" removes all outgoing Via: headers)
    # Set to one of: Off | On | Full | Block
    #ProxyVia On
    # To enable the cache as well, edit and uncomment the following lines:
    # (no cacheing without CacheRoot)
    #CacheRoot "/var/cache/apache"
    #CacheSize 5
    #CacheGcInterval 4
    #CacheMaxExpire 24
    #CacheLastModifiedFactor 0.1
    #CacheDefaultExpire 1
    #NoCache a_domain.com another_domain.edu joes.garage_sale.com
</IfModule>
# End of proxy directives.
### Section 3: Virtual Hosts
# VirtualHost: If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them.
# Please see the documentation at <URL:http://www.apache.org/docs/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
# If you want to use name-based virtual hosts you need to define at
# least one IP address (and port number) for them.
#NameVirtualHost 12.34.56.78:80
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
#</VirtualHost>
#<VirtualHost _default_:*>
#</VirtualHost>
# Automatically added by the post-installation script
# as part of the transition to a config directory layout
# similar to apache2, and that will help users to migrate
# from apache to apache2 or revert back easily
Include /etc/apache/conf.d
si tu trouve GG ^^
Pour apache2, il faut éditer ce fichier :
mgserv
par mgserv »
que dois je modifier dans ce fichier
NameVirtualHost *
<VirtualHost *>
	<Directory />
		Options FollowSymLinks
		AllowOverride None
	</Directory>
	<Directory /var/www/>
		AllowOverride None
		Order allow,deny
		allow from all
		# This directive allows us to have apache2's default start page
                # in /apache2-default/, but still have / go to the right place
		RedirectMatch ^/$ /apache2-default/
	</Directory>
	<Directory "/usr/lib/cgi-bin">
		AllowOverride None
		Order allow,deny
		Allow from all
	</Directory>
	ErrorLog /var/log/apache2/error.log
	# Possible values include: debug, info, notice, warn, error, crit,
	# alert, emerg.
	LogLevel warn
	CustomLog /var/log/apache2/access.log combined
	ServerSignature On
    Alias /doc/ "/usr/share/doc/"
    <Directory "/usr/share/doc/">
        Options Indexes MultiViews FollowSymLinks
        AllowOverride None
        Order deny,allow
        Deny from all
        Allow from 127.0.0.0/255.0.0.0 ::1/128
    </Directory>
</VirtualHost>
mgserv
par mgserv »
je lai fait ^^
j ai relancer et ma m ecris imossible de trouver la page PDT_014 meme avec les droits 777 sur le dossier
je comprend pas trop
modifie aussi là : <Directory /var/www/>
les fichiers aussi sont en 777 ?
mgserv
par mgserv »
j ai modifier aussi et tjs la même chose
non le fichier de destination et a 777 cest a dire la /home/www c'est tout
<VirtualHost *>
	DocumentRoot /home/www/
	<Directory />
		AllowOverride None
	</Directory>
	<Directory /home/www/>
		AllowOverride None
		Order allow,deny
		allow from all
	</Directory>
et quand je me connecte j ai ceci sur internet explorueur
 La page est introuvable
Il est possible que la page recherchée ait été supprimée, que son nom ait changé ou qu'elle ne soit pas disponible pour le moment.
Essayez de la manière suivante :
Si vous avez entré l'adresse de cette page dans la barre d'adresses, vérifiez qu'elle est correcte.
Ouvrez la page de démarrage ns21265.ovh.netet recherchez les liens vers les informations que vous désirez.
Cliquez sur le bouton  Précédente pour essayer un autre lien.
Cliquez sur  Rechercher pour trouver des informations sur Internet.
HTTP 404 - Fichier introuvable
Internet Explorer
fais ça :
echo hihi > /home/www/index.html
chown -R 777 /home/www/
et retente d'afficher le site.
mgserv
par mgserv »
non la quand je veux me connecter il me telecharge un fichier de type inconnu PDT_007
tu as tappé quoi comme adresse ?
je vois un truc ovh.
mgserv
par mgserv »
oui c'est bien sa
http://ns21265.ovh.net/
mais la jai remis tous comme c tt avant c est a dire dans /war/www
Remets sur /home/www et commente cette ligne :
et retente d'aller sur le site pour voir :)
mgserv
par mgserv »
pkoi la commenter ? si je met /home/www sa ne fonctionne pas
, quand je laisse /war/www sa fonctionne
j ai même tester avec apache c identique
donc je crois que je v abandonner et le laisser sur /var/www
merci quand même
