All processes killed
========== REGISTRY ==========
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\NvCplDaemon deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\NvMediaCenter deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\nwiz deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\SoundMan deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\ULiRaid5289 deleted successfully.
[EMPTYTEMP]
User: Alain
->Temp folder emptied: 559170 bytes
->Temporary Internet Files folder emptied: 266338 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 99140644 bytes
->Google Chrome cache emptied: 0 bytes
->Opera cache emptied: 240 bytes
->Flash cache emptied: 1650 bytes
User: All Users
User: Default User
->Temporary Internet Files folder emptied: 0 bytes
User: LocalService
->Temp folder emptied: 66016 bytes
->Temporary Internet Files folder emptied: 33170 bytes
->Flash cache emptied: 0 bytes
User: NetworkService
%systemroot%\System32\dllcache .tmp files removed: 0 bytes
Windows Temp folder emptied: 98304 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 0 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 0 bytes
RecycleBin emptied: 62159824 bytes
Total Files Cleaned = 155,00 mb
[EMPTYFLASH]
User: Alain
User: All Users
User: Default User
User: LocalService
Total Flash Files Cleaned = 0,00 mb
OTL by OldTimer - Version 3.2.54.0 log created on 07192012_173656
PendingFileRenameOperations files...
Probleme vidéos saccadées
Re: Probleme vidéos saccadées
le voila!
Relance OTL et clic sur Purge outil.
C'est mieux ou toujours pareil ?
effectivement, c'est déjà mieux!
C'est Ok
Finir le nettoyage :
Supprime :
Règle-le d'abord comme ici :
Supprime :
- Clique sur le Pinceau,
- Lancer le Nettoyage.
- Patiente,
- Chercher des erreurs,
- OK,
- Tu peux fermer CCleaner.
- Propriétés,
- Décochez :
et bien merci encore!!
Re: [Résolu] Probleme vidéos saccadées
Mince, je pensais que c'était bon, mais les vidéos saccadent toujours... :(
Si tu laisses les vidéos charger en appuyant le bouton pause ça saccade toujours ?
oui, toujours.
Mais dès que je change de page, que j'ai un peu d'activité sur mon ordi (ouverture de dossiers,...), le son saute, c'est assez étrange, je n'avais pas ça avant...
Tiens, je remarque que les vidéos, mêmes les plus courtes, ne se chargent pas en entier...
Quelle est la qualité des vidéos ? 240p, 360p, 480p ou plus ?
qualités les plus basses (le HD passe mal, mais même avant que les vidéos saccadent)
D'accord, quand tu lis une vidéo, dans le Gestionnaire des tâches, onglet Performances, ça donne quoi pour l'UC et la ram utilisé ?
L'UC varie entre 20 et 30% mais la ram reste de 1480Mo environ (voir un peu plus)
Essaye ça : http://support.google.com/youtube/bin/a ... er=1230977
Poste ta config : http://www.vulgarisation-informatique.com/everest.php
Si ton UC n'est pas à 100 % ça devrait être niquel quand tu regardes une vidéo...
J'ai fais un rapport, le voici:
--------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
Version EVEREST v2.20.405/fr
Site web http://www.lavalys.com/
Type de rapport Générateur de rapports
Ordinateur AL1
Générateur Alain
Système d'exploitation Microsoft Windows XP Home Edition 5.1.2600 (WinXP Retail)
Date 2012-07-21
Heure 12:09
--------[ Résumé ]------------------------------------------------------------------------------------------------------
Ordinateur:
Service Pack du système Service Pack 3
DirectX 4.09.00.0904 (DirectX 9.0c)
Nom du système AL1
Nom de l'utilisateur Alain
Carte mère:
Type de processeur AMD Athlon 64, 2200 MHz (11 x 200) 3500+
Nom de la carte mère ASRock K8 Combo-Z (3 PCI, 1 AGP, 5 DDR DIMM, Audio, LAN)
Chipset de la carte mère ULi/ALi M1689, AMD Hammer
Mémoire système 1536 Mo (PC3200 DDR SDRAM)
Type de BIOS AMI (06/08/05)
Port de communication Port de communication (COM1)
Port de communication Port imprimante ECP (LPT1)
Moniteur:
Carte vidéo NVIDIA GeForce FX 5200 (128 Mo)
Accélérateur 3D nVIDIA GeForce FX 5200
Moniteur Écran Plug-and-Play [NoDB] (ETL4108012)
Multimédia:
Carte audio ULi/ALi M5455 AC'97 Audio Controller
Stockage:
Contrôleur IDE Contrôleur IDE PCI Bus Master ALi M5229
Contrôleur SCSI/RAID A347SCSI SCSI Controller
Contrôleur SCSI/RAID ULi SATA/RAID Controller (M1689/M1567)
Lecteur de disquettes Lecteur de disquettes
Disque dur WDC WD1600JB-22FUA0 (149 Go, IDE)
Lecteur optique AXV CD/DVD-ROM SCSI CdRom Device (Virtual DVD-ROM)
Lecteur optique HL-DT-ST DVDRAM GSA-H10N
État des disques durs SMART OK
Partitions:
C: (NTFS) 152625 Mo (18441 Mo libre)
Entrée:
Clavier Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
Souris Souris à roulette USB Logitech
Réseau:
Carte réseau ULi PCI Fast Ethernet Controller (192.168.0.14)
Modem Modem standard 33600 bps
Périphériques:
Imprimante Auto Epson Stylus COLOR 1520 ESC/P 2 sur PASCAL-PERSO
Imprimante Auto EPSON Stylus COLOR 1520 sur PASCAL-PERSO
Imprimante EPSON Stylus DX7400 Series
Imprimante Microsoft XPS Document Writer
Contrôleur USB1 ULi/ALi M5237 USB Open Host Controller
Contrôleur USB2 ULi/ALi M5273 USB 2.0 Host Controller
Périphérique USB Souris à roulette USB Logitech
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B00 D00 F00: ULi/ALi M1689 Chipset - System Controller
Offset 00: B9 10 89 16 06 01 10 00 00 00 00 06 00 00 00 00
Offset 10: 08 00 00 F8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 08 60 20 00 20 03 01 01 D0 00 00 00 24 05 35 00
Offset 50: 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 08 80 18 80 44 01 92 F8 00 00 00 00 00 05 17 50
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 02 00 30 00 0B 02 00 1B 02 03 00 00 08 00 20 00
Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D01 F00: ULi/ALi M5246 AGP 3.0 Controller
Offset 00: B9 10 46 52 07 01 20 00 00 00 04 06 00 00 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 01 01 40 F0 00 20 22
Offset 20: A0 FC A0 FE 90 E4 80 F4 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0B 00
Offset 40: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 20 78 00 C0 00 20 20 20 20 20 00 00 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 11 00 00 00 00 11 00 01 24 27
B00 D02 F00: ULi/ALi M5249 Hypertransport-PCI Bridge
Offset 00: B9 10 49 52 07 01 00 00 00 01 04 06 00 00 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 02 02 20 F0 00 00 22
Offset 20: F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00
Offset 40: 00 80 00 78 00 00 00 00 80 00 00 20 00 00 00 00
Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D03 F00: ULi/ALi M1563 South Bridge with HyperTransport Support
Offset 00: B9 10 63 15 0F 00 00 02 70 00 01 06 00 00 80 00
Offset 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 63 15
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 18
Offset 40: F7 E4 00 09 3D FA 00 00 00 00 00 00 03 C0 00 10
Offset 50: 02 00 02 00 0D 09 01 80 FF 39 FB 07 A1 60 10 00
Offset 60: D8 F8 C0 F2 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 07 63 15 00 0F 00 00 00 00 00 20 00 00 00 00
Offset 80: 03 04 00 00 21 0F CC DD EE 99 AA 99 00 BB 00 5F
Offset 90: 00 00 03 00 00 00 00 00 1E 00 00 00 00 00 E0 FE
Offset A0: 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: DA 80 01 00 C0 00 F0 00 5F 00 00 00 00 00 00 00
B00 D03 F01: ULi/ALi M7101 Power Management Controller
Offset 00: B9 10 01 71 00 00 00 02 00 00 80 06 00 00 80 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 01 71
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 00 40 08 00 00 00 20 00 0C 78 00 00 00 00 00 00
Offset 50: 00 07 FF 42 00 00 00 00 00 DF 0F 10 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 FF 3F 3F 3F
Offset 70: FF 07 00 00 00 00 00 08 76 88 B0 08 3C FE FF 00
Offset 80: 32 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: FF 44 80 20 00 FF FF 07 00 00 28 70 40 9B 02 00
Offset C0: 12 00 10 10 00 00 00 00 00 00 FF 00 00 00 00 00
Offset D0: 00 42 04 00 40 00 22 00 4C 0F 00 00 02 00 00 00
Offset E0: 00 08 00 00 0E 29 CB 55 B4 00 01 00 00 00 00 36
Offset F0: 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00
B00 D04 F00: ULi/ALi M5455 AC'97 Audio Controller
Offset 00: B9 10 55 54 17 00 10 02 20 00 01 04 10 20 00 00
Offset 10: 01 E8 00 00 00 F0 BF FE 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 50 08
Offset 30: 00 00 00 00 40 00 00 00 00 00 00 00 12 01 40 00
Offset 40: 01 00 22 E6 00 00 00 00 04 00 00 00 00 00 00 00
Offset 50: 49 18 50 08 10 00 C4 00 40 00 0C 00 00 00 00 00
Offset C0: 00 00 57 54 00 00 00 00 00 00 00 00 00 00 00 00
B00 D0D F00: ULi/ALi M5263 Fast Ethernet Controller
Offset 00: B9 10 63 52 07 00 10 02 40 00 00 02 08 20 00 00
Offset 10: 01 E4 00 00 00 EC BF FE 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 63 52
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 11 01 14 28
Offset 40: 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 01 00 22 C0 00 00 00 00 00 00 00 00 00 00 00 00
B00 D0E F00: ULi/ALi M5229 IDE Controller
Offset 00: B9 10 29 52 05 00 A0 02 C7 FA 01 01 00 20 80 00
Offset 10: F1 01 00 00 F5 03 00 00 71 01 00 00 75 03 00 00
Offset 20: 01 FF 00 00 00 00 00 00 00 00 00 00 B9 10 29 52
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00
Offset 40: 00 00 00 7A 4D 10 00 C0 00 80 64 C1 00 00 BA 1A
Offset 50: 02 00 00 83 50 55 4A 44 01 31 31 31 01 31 31 31
Offset 60: 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 00 00 00 01 00 01 00 00 00 00 00 00 00 00 00
B00 D0E F01: ULi/ALi M5289 SATA RAID Controller
Offset 00: B9 10 89 52 05 01 A0 02 10 8F 80 01 80 80 80 00
Offset 10: 81 0F 00 00 01 0F 00 00 81 0E 00 00 01 0E 00 00
Offset 20: 81 D8 00 00 00 00 00 00 00 00 00 00 49 18 89 52
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 13 01 00 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 1F 00 00 0F 10 01 00 00 00 68 00 68 00
Offset 90: 00 00 00 00 00 04 80 00 10 00 00 00 00 00 00 00
Offset A0: 00 00 00 00 00 04 80 00 10 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 88 B1 0E 00 00 00 00 00 00 00 00 00
B00 D0F F00: ULi/ALi M5237 USB Open Host Controller
Offset 00: B9 10 37 52 17 01 A8 02 03 10 03 0C 10 20 80 00
Offset 10: 00 D0 BF FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 37 52
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 14 01 00 50
Offset 40: 00 00 1F 00 E0 40 00 00 00 00 00 00 00 00 00 00
Offset 60: 01 00 02 FE 00 80 00 00 00 00 00 00 00 00 00 00
B00 D0F F01: ULi/ALi M5237 USB Open Host Controller
Offset 10: 00 C0 BF FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 15 02 00 50
Offset 40: 00 00 1F 00 E0 48 00 00 00 00 00 00 00 00 00 00
B00 D0F F02: ULi/ALi M5237 USB Open Host Controller
Offset 10: 00 B0 BF FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 16 03 00 50
Offset 60: 01 00 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
B00 D0F F03: ULi/ALi M5273 USB 2.0 Host Controller
Offset 00: B9 10 39 52 16 01 B0 02 01 20 03 0C 10 20 80 00
Offset 10: 00 E8 BF FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 39 52
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 17 04 10 20
Offset 40: 20 03 00 C4 80 02 10 C4 00 00 00 00 00 00 00 00
Offset 50: 01 58 02 C8 00 00 00 00 0A 00 90 20 00 00 00 00
Offset 60: 20 20 7F 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 01 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00
B00 D18 F00: AMD Hammer - HyperTransport Technology Configuration
Offset 00: 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
Offset 30: 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
Offset 50: 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
Offset 60: 00 00 00 00 E4 00 00 00 0F CC 00 0F 1C 00 00 00
Offset 80: 08 00 01 21 20 00 11 10 22 05 75 80 02 00 00 00
Offset 90: 56 04 51 02 00 00 FF 00 07 00 00 00 00 00 00 00
B00 D18 F01: AMD Hammer - Address Map
Offset 00: 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
Offset 40: 03 00 00 00 00 00 5F 00 00 00 00 00 01 00 00 00
Offset 50: 00 00 00 00 02 00 00 00 00 00 00 00 03 00 00 00
Offset 60: 00 00 00 00 04 00 00 00 00 00 00 00 05 00 00 00
Offset 70: 00 00 00 00 06 00 00 00 00 00 00 00 07 00 00 00
Offset B0: 03 0A 00 00 00 0B 00 00 03 00 60 00 00 FF FF 00
Offset C0: 13 10 00 00 00 F0 FF 00 00 00 00 00 00 00 00 00
Offset E0: 03 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00
B00 D18 F02: AMD Hammer - DRAM Controller
Offset 00: 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
Offset 40: 01 00 00 04 01 00 00 05 00 00 00 00 00 00 00 00
Offset 50: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 00 FE E0 00 00 FE E0 00 00 00 00 00 00 00 00 00
Offset 70: 00 FE E0 03 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 04 09 00 00 00 00 00 00 45 35 82 13 31 0B 00 00
Offset 90: 40 8E 0C 18 07 07 5B 3E 00 00 00 00 0A 02 00 00
Offset B0: 1D 47 06 16 11 00 00 00 CC 0F 10 04 10 52 66 88
Offset C0: 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 03 B5 10 11 13 A1 60 1A 83 2D 94 69 41 30 ED A0
Offset E0: 53 0E D1 B5 0A 5D 02 14 B0 81 E1 01 40 60 1F 60
B00 D18 F03: AMD Hammer - Miscellaneous Control
Offset 00: 22 10 03 11 00 00 00 00 00 00 00 06 00 00 80 00
Offset 40: FF 3B 00 00 40 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 C0 01 1F CE
Offset 60: 05 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00
Offset 70: 11 01 02 51 11 80 00 50 00 38 00 08 1B 22 00 00
Offset 80: 21 23 07 23 13 21 13 21 00 00 00 00 00 00 00 00
Offset 90: 03 00 00 00 7C 00 00 00 30 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 00 00 00 00 3B 00 00 00 01 40 03 78
Offset D0: 00 00 00 00 01 07 0D 00 00 00 40 00 00 00 00 00
Offset E0: 00 00 00 00 20 05 58 07 19 05 00 00 00 00 00 00
B01 D00 F00: Asus V9520-X Video Adapter
Offset 00: DE 10 22 03 07 00 B0 02 A1 00 00 03 00 F8 00 00
Offset 10: 00 00 00 FD 08 00 00 E8 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 80 81
Offset 30: 00 00 00 00 60 00 00 00 00 00 00 00 10 01 05 01
Offset 40: 43 10 80 81 02 00 30 00 1B 0E 00 1F 02 03 00 1B
Offset 50: 01 00 00 00 01 00 00 00 CE D6 23 00 0F 00 00 00
Offset 60: 01 44 02 00 00 00 00 00 00 00 00 00 00 00 00 00
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
C000:0000 U.|.K7400.L.w.VIDEO ....<.....IBM VGA Compatible........08/18/04
C000:0040 .................(..C......~............"..P......PMIDl.o.......
C000:0080 .....3...........NV..)..|. 4.................T.P.#L...;.<nC#C7C
C000:00C0 ..7.[n.............`...0W...n.o.o.o.o.o.o.......................
C000:0100 ...3.b.......~nan...............r.y...p....(#..P2Bend bmp..PCIR
C000:0140 ..".........|.......ASUS V9520-X VGA BIOS Version 4.34.20.87.AS0
C000:0180 7....................................Version 4.34.20.87.00 ...Co
C000:01C0 pyright (C) 1996-2003 NVIDIA Corp...............................
C000:0200 ....................NV34 Board - c116dn ..............Chip Rev
C000:0240 ....................1...`.&...6.;.p.....I...L.....>.a...R..ke.
C000:0280 ..;.;.;...%...;.n...G.q.;...t...|...x.'.H.2.f`....n.............
C000:02C0 ...u..fa....f`3....fa....C.+....V.......u.........8...t......2..
C000:0300 ...t..Q.........Y.f..7.....cf.#....f........u...c.f..7...f......
C000:0340 ..u..zc.f..7...f+.........u.S..q[..i.fVf.......cfPf%.....FcfXf^.
C000:0380 fSf..fVf......lcf%....f.....`f....cf^f[.fPf.......fX......f`...f
C000:03C0 ....`t.......f....f...h..mrf.....f3.f..f.......bf.....f.q.....bf
--------[ Debug - Unknown ]---------------------------------------------------------------------------------------------
Monitor ACRAD41: Écran Plug-and-Play [NoDB]
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
Ca donne rien pour l'accélération matérielle ?
Essaue toujours de réinstaller ton pilote graphique : http://www.nvidia.fr/object/winxp_2k_81.95_fr.html
- 0 Réponses
- 184 Vues
- 18 Réponses
- 903 Vues
Dernier message par HAL9000
- 0 Réponses
- 128 Vues
Dernier message par jleroy
- 74 Vues
- 47 Réponses
- 1842 Vues
