merci.
Par contre c'est quoi ce pack au juste?
Rapport :
Scan saved at 20:37:20, on 30/01/2011
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Avira\AntiVir Desktop\sched.exe
C:\Program Files\Avira\AntiVir Desktop\avguard.exe
C:\Program Files\Windows Live\Family Safety\fsssvc.exe
C:\Program Files\Avira\AntiVir Desktop\avshadow.exe
C:\WINDOWS\system32\wuauclt.exe
C:\WINDOWS\system32\WgaTray.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Avira\AntiVir Desktop\avgnt.exe
C:\Program Files\Avira\AntiVir Desktop\avmailc.exe
C:\Program Files\Avira\AntiVir Desktop\AVWEBGRD.EXE
C:\WINDOWS\system32\msiexec.exe
C:\WINDOWS\system32\MsiExec.exe
O2 - BHO: HP Print Enhancer - {0347C33E-8762-4905-BF09-768834316C61} - C:\Program Files\HP\Smart Web Printing\hpswp_printenhancer.dll
O2 - BHO: HP Print Clips - {053F9267-DC04-4294-A72C-58F732D338C0} - C:\Program Files\HP\Smart Web Printing\hpswp_framework.dll
O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir Desktop\avgnt.exe" /min
O4 - HKUS\S-1-5-19\..\RunOnce: [Config] %systemroot%\system32\run.cmd (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-19\..\RunOnce: [nlsf] cmd.exe /C move /Y "%SystemRoot%\System32\syssetub.dll" "%SystemRoot%\System32\syssetup.dll" (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-19\..\RunOnce: [tscuninstall] %systemroot%\system32\tscupgrd.exe (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-20\..\RunOnce: [Config] %systemroot%\system32\run.cmd (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-18\..\RunOnce: [Config] %systemroot%\system32\run.cmd (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [Config] %systemroot%\system32\run.cmd (User 'Default user')
O9 - Extra button: Ajout Direct - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra 'Tools' menuitem: &Ajout Direct dans Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra button: Livre de reliures HP - {58ECB495-38F0-49cb-A538-10282ABF65E7} - C:\Program Files\HP\Smart Web Printing\hpswp_extensions.dll
O9 - Extra button: Sélection intelligente HP - {700259D7-1666-479a-93B1-3250410481E8} - C:\Program Files\HP\Smart Web Printing\hpswp_extensions.dll
O23 - Service: Avira AntiVir MailGuard (AntiVirMailService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\avmailc.exe
O23 - Service: Avira AntiVir Planificateur (AntiVirSchedulerService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\sched.exe
O23 - Service: Avira AntiVir Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\avguard.exe
O23 - Service: Avira AntiVir WebGuard (AntiVirWebService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\AVWEBGRD.EXE
End of file - 3323 bytes
[résolu] Ram carte mere HP omnibook XE4100
Re: Ram carte mere HP omnibook XE4100
C'est un des nombreux programmes inutiles de la suite Windows Live.
Pour supprimer WGA : http://www.commentcamarche.net/faq/3625 ... -advantage
Après ça le PC devrait être plus rapide.
désolée de repasser si tard.
Merci de ton aide et de ta patience, je vais finir de desinstaller les logiciels.
Je te remercie. Je vais suivre ce tuto afin de nettoyer mon pc principal.
merci a toi
merci a toi
Re: [résolu] Ram carte mere HP omnibook XE4100
C'est Ok
Finir le nettoyage :
Supprime :
Règle-le d'abord comme ici :
Supprime :
- Clique sur le Pinceau,
- Lancer le Nettoyage.
- Patiente,
- Chercher des erreurs,
- OK,
- Tu peux fermer CCleaner.
- Propriétés,
- Décochez :
J'en suis ici :
- Propriétés,
- Décochez :
encore merci
Licence windows plus reconnue sutie changement carte mère
par patriceb » » dans Windows : Résoudre les problèmes - 1 Réponses
- 40 Vues
- 151 Vues
- 33 Vues
- 9 Réponses
- 186 Vues
Dernier message par Foks
- 2 Réponses
- 40 Vues
Dernier message par STEPHANE40
