SkyTech a écrit :Relance OTL.
o sous Personnalisation, copie_colle le contenu du cadre ci dessous et clic Correction, un rapport apparaitra suite à l'opération que tu conserveras sur clé usb par exemple afin d'en coller le résultat:
:OTL
DRV - (NwlnkFwd) -- C:\Windows\System32\DRIVERS\nwlnkfwd.sys File not found
DRV - (NwlnkFlt) -- C:\Windows\System32\DRIVERS\nwlnkflt.sys File not found
DRV - (IpInIp) -- C:\Windows\System32\DRIVERS\ipinip.sys File not found
[2010/09/24 21:10:52 | 000,000,000 | ---D | M] (No name found) -- C:\Users\katia\AppData\Roaming\Mozilla\Extensions\{3550f703-e582-4d05-9a08-453d09bdfdc6}
[2010/10/07 13:37:32 | 000,000,000 | ---D | C] -- C:\Program Files\Rising
[2010/10/07 13:36:57 | 000,000,000 | ---D | C] -- C:\ProgramData\Rising
le rapport
========== OTL ==========
Service NwlnkFwd stopped successfully!
Service NwlnkFwd deleted successfully!
File C:\Windows\System32\DRIVERS\nwlnkfwd.sys File not found not found.
Service NwlnkFlt stopped successfully!
Service NwlnkFlt deleted successfully!
File C:\Windows\System32\DRIVERS\nwlnkflt.sys File not found not found.
Service IpInIp stopped successfully!
Service IpInIp deleted successfully!
File C:\Windows\System32\DRIVERS\ipinip.sys File not found not found.
C:\Users\katia\AppData\Roaming\Mozilla\Extensions\{3550f703-e582-4d05-9a08-453d09bdfdc6} folder moved successfully.
C:\Program Files\Rising\Settings\22\Rav folder moved successfully.
C:\Program Files\Rising\Settings\22 folder moved successfully.
C:\Program Files\Rising\Settings folder moved successfully.
C:\Program Files\Rising\Rav\CopyRun folder moved successfully.
C:\Program Files\Rising\Rav folder moved successfully.
C:\Program Files\Rising folder moved successfully.
C:\ProgramData\Rising\Rav\Data folder moved successfully.
C:\ProgramData\Rising\Rav folder moved successfully.
C:\ProgramData\Rising\common folder moved successfully.
C:\ProgramData\Rising folder moved successfully.
OTL by OldTimer - Version 3.2.15.2 log created on 10172010_140432
chkdsk en cours
