Antivir 9
Citoyen
Re: Antivir 9
par Citoyen »
D'après la lettre d'info malekal:
"Liste des modifications (en anglais) depuis ce lien :
http://forum.avira.com/wbb/index.php?pa ... adID=85047"
The link you are trying to reach is no longer available or is invalid.
PDT_033
cpasmafaute1
Re: Antivir 9
par cpasmafaute1 »
Androcure06
Re: Antivir 9
par Androcure06 »
What's new in Avira AntiVir Personal - Free Antivirus 9.0.0.386:· Quarantine manager: the number of columns has been reduced
· Quarantine manager: send files using HTTP
· System tray tool: display the status of modules on mouse-over
· Last system scan: individual configuration of the alert message
· Renaming "Win32 Heuristic" to "AHeAD" in the configuration panel
· Support for netbooks (screen resolution)
· Configuration panel: new button "Default Values". This button allows you to restore the configuration to the predefined default values
· New installation folder and registry keys for all products: "C:Program FilesAviraAntiVir Desktop" and "HKLMSoftwareAviraAntiVir Desktop".Now there are no differences between the products AntiVir Personal, AntiVir Premium and Premium Security Suite any longer
· Configuration wizard after setup
· Process protection for GUI processes
· File and folder protection for AntiVir files and folders
· Registry protection for AntiVir keys
· Scanning of locked files
· Scanner: combined display of malware detections and one-click removal after an on demand scan. This option can be set in the scanner configuration
· Scanner: improved system disinfection
· Scanner: optimized scan on multi-processor machines
· Guard: less overhead in memory
· Scheduler: scheduling on multiple days of the week
· Scheduler: manual starting and stopping of jobs
· Ad-/Spyware detection
Avira AntiVir Premium 9.0.0.420
· An enhanced interface graphical interface,
· A modularized AV-search engine for improved scan performance,
· An integrated failsafe security system, and SMTP support for AntiVir MailGuard,
· NEW modules: WebGuard and Rescue System.
Premium functions:
· Low system resources used;
· Control Center for monitoring, administering and controlling the entire program;
· Central configuration with user-friendly standard and advanced options and ontext-sensitive help;
· Scanner (On-Demand Scan) with profile-controlled and configurable search for all known types of virus and malware;
· Guard (On-Access Scan) for continuous monitoring of all file access attempts;
· MailGuard (POP3- and SMTP-Scanner) for the permanent checking of emails for
· viruses and malware. Checking of email attachments is included;
· Exclusive download server for faster updates;
· User-defined update intervals;
· Phishing and Rootkit Protection.
Re: Antivir 9
par angelique »
Une nouvelle Vid de configuration d'antivir version 9 ,comment les cases doivent etre cochées:
http://senduit.com/ac293c
malekal , si tu veux l'héberger lol
Merci :: https://www.malekal.com/fichiers/antivi ... ivirV9.avi
Re: Antivir 9
Re: Antivir 9
par SkyTech »
Thx angelique PDT_001
Re: Antivir 9
par angelique »
Just pour informer Léo
Situation::
» situation identique sur les 2 pc!
*2 pc XP pro coporate SP1
*chargement de la version 9 sur Freeav.com : avira_antivir_personal_en
*desinstallation de la v8 normallement + suppression rep. restant en %programfiles%\ et partout ..alluser...+ supp des legacy "ssmdrv"
*reboot
*installation de la v9 à partir du setup , tout se passe "bien" , mais y'a le droit à un "flash" reboot
==> un tour dans eventvwr au reboot pour voir , et y'a cette erreur , enfin je mets toutes les errors :
An error occurred during a resource request to the Windows NT system. The resource <INIT11> has not been allocated. This could be due to an out-of-memory error or any other system failure. Returned error code: 0x2
Le service "AntiVirSchedulerService" n'a peut-être pas annulé son inscription au service de notifications d'événement de périphériques avant d'être arrêté.
Product: Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 -- Configuration completed successfully
L'appel ScRegSetValueExW a échoué pour Type avec l'erreur :
Accès refusé.
* au reboot je relance le setup de la V9 , je choisi Custom....... etc ... le prod s'installe bien , je configure (je fais une Vid lol :: https://www.malekal.com/fichiers/antivi ... ivirV9.avi ) sur comment cocher les cases au mieux , on va dire, antivir version V9 marche merveilleusement bien.
Juste pour info /!\ :: le guard se colle là ?c'est nouveau lol :: C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\avguard.tmp 20558729 Fichier TMP 18/03/2009 17:38:46 A
Leo 2005
Re: Antivir 9
par Leo 2005 »
oui le problème avec le scheduler est connu. ça va être surement corriger avec une mise à jour.
Pour la configurationsi c'est le mieux. hm moi je ne trouve pas, mais chaqu'un à ces prèférences ;)
Felix
Re: Antivir 9
par Felix »
Le bonjour à tous...
Je viens de passer manuellement à la version 9 premium sur mon poste et à la 9 free sur celui de mon fiston. Aucun problème sinon de l'attente pour le téléchargement de la 9 free. Les maj semblent plus rapides et les scans ne trouvent plus que 1 warning au lieu des 5 à 6 habituels. Bref, ça tourne bien. PDT_001
Felix
Re: Antivir 9
par Felix »
Re...
Autre avantage : plus léger encore que la version 8 ( scan Hijackthis à l'appui ).
Ça roule...
Re: Antivir 9
par SkyTech »
Felix a écrit : Autre avantage : plus léger encore que la version 8 ( scan Hijackthis à l'appui ).
A ça m'intéresse PDT_001
Tu pourrais poster le log HijackThis ?
Re: Antivir 9
Je vois pas comment tu peux utiliser l'utilisation de ressources (CPU, mémoires etc) avec un scan HijackThis.
passagère
Re: Antivir 9
par passagère »
Leo 2005 a écrit :Merci de noter que la version française ne vas pas être disponible directement. Pour le début il n'y aura que la version anglaise et allemande.
a+
oui mais combien, combien de temps, 1 semaine PDT_001
1 mois PDT_008
1 an PDT_030
bye bye
Re: Antivir 9
par SkyTech »
Passagère a écrit :Bonjour,
a+
1 mois PDT_008
1 an PDT_030
bye bye
Leo 2005 a écrit :la version française va être disponibe le 28 avril.
Leo 2005
Re: Antivir 9
par Leo 2005 »
Malekal_morte a écrit :Je vois pas comment tu peux utiliser l'utilisation de ressources (CPU, mémoires etc) avec un scan HijackThis.
je crois qu'il veut seulement dire qu'il y a un service de moin. le avesvc.exe n'existe plus
