Scan saved at 20:10:50, on 15/03/2009
MSIE: Internet Explorer v7.00 (7.00.6000.16791)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
C:\Program Files\Java\jre6\bin\jusched.exe
C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe
C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
C:\WINDOWS\system32\wuauclt.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.orange.fr
O2 - BHO: AGSearchHook Class - {0BC6E3FA-78EF-4886-842C-5A1258C4455A} - C:\Program Files\AGI\common\agcutils.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe" /min
O8 - Extra context menu item: Add to Google Photos Screensa&ver - res://C:\WINDOWS\system32\GPhotos.scr/200
O8 - Extra context menu item: Envoyer au périphérique &Bluetooth... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/s ... wflash.cab
O23 - Service: AG Windows Service (AGWinService) - Unknown owner - C:\Program Files\AGI\common\win32\PythonService.exe
O23 - Service: Planificateur Avira AntiVir Personal - Free Antivirus (AntiVirScheduler) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
O23 - Service: Avira AntiVir Personal - Free Antivirus Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Fichiers communs\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: Process Monitor (LVPrcSrv) - Logitech Inc. - C:\Program Files\Fichiers communs\LogiShrd\LVMVFM\LVPrcSrv.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\System32\HPZipm12.exe
End of file - 3823 bytes
[Résolu] Problème à l'installation du service Pack 3
Re: Problème à l'installation du service Pack 3
Est-ce toi qui a installé ça ?
Fix ces lignes :
Supprime :
C:\Program Files\IncrediMail
lafreliflo a écrit :O2 - BHO: AGSearchHook Class - {0BC6E3FA-78EF-4886-842C-5A1258C4455A} - C:\Program Files\AGI\common\agcutils.dll
Fix ces lignes :
As-tu virer Windows Messenger ?O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
Supprime :
Oui normalement j'ai viré windows messenger, par contre je m'aperçois que je n'ai plus WLM, en fin pas de raccourci.
Pour ce que tu me demandes si c'est moi qui ai installé ça, je ne sais même pas ce que c'est.
Bon je fais ce que tu m'as demandé de faire
Désinstalle-le\réinstalle-le.
Si besoin utilise Windows Installer CleanUp
Ça c'est pas normal.lafreliflo a écrit :par contre je m'aperçois que je n'ai plus WLM, en fin pas de raccourci.
Vois si ça ce désinstalle proprement.lafreliflo a écrit :Pour ce que tu me demandes si c'est moi qui ai installé ça, je ne sais même pas ce que c'est.
Bon pour WLM, c'est bon, y a eu un p'tit flottement, mais je peux l'ouvrir et m'en servir.SkyTech a écrit :Re,
Pour le reste, je fais comment? je passe par Hijack et je fais fix checked sur ces 2 lignes?
Essaye de voir si ça se désinstalle proprement via ajout/supression de programme.
Bonsoir!
J'ai désinstallé via ajout/suppression de programme et il reste des traces dans program files
Scan saved at 21:23:42, on 15/03/2009
Boot mode: Normal
Running processes:
C:\Program Files\Internet Explorer\iexplore.exe
End of file - 3632 bytes
Boot mode: Normal
Running processes:
Hum toujours là dans ton log pourtant. Attends Skytech voir ce qu'il dit
Lu Magnak
Fix cette ligne :
* Menu Démarrer, clique sur exécuter
* Tape cmd et valide avec ok
* Dans l'invite qui s'ouvre, copie et colle cette ligne
sc stop AGWinService
Si un message d'erreur s'affiche, poursuit quand même
* Valide avec OK
* Copie-colle maintenant ça dans la fenêtre:
sc delete AGWinService
* Valide avec OK
Supprime :
Redémarre et reposte un denier log.
Lu Magnak
Fix cette ligne :
Puis :O2 - BHO: AGSearchHook Class - {0BC6E3FA-78EF-4886-842C-5A1258C4455A} - C:\Program Files\AGI\common\agcutils.dll
* Valide avec OK
* Valide avec OK
Supprime :
Scan saved at 21:44:36, on 15/03/2009
Boot mode: Normal
Running processes:
End of file - 3349 bytes
Boot mode: Normal
Running processes:
Pas de soucis, skytech, je peux comprendre ta réaction.
Mais j'en suis où moi, j'ai toujours suivi tes conseils alors je continue, et mon PC ne s'en porte que mieux.
Alors suis-je au bout de mes peines?
@ vulcain la suite ici : http://forum.malekal.com/viewtopic.php?f=73&t=18078
Dsl j'ai dû delete ton message en déplacent, il encore en citation.
Est-ce plus rapide ?
C'est Ok
Finir le nettoyage :
Supprime :
Tu peut désinstaller les programmes que nous avons utilisé via ajout\suppression de programmes ou via
désinstaller un programme (Vista)
Clique sur le pinceau puis, sur lancer le nettoyage.
Ensuite sur Registre, chercher des erreurs, une fois l'analyse terminer clique sur réparer les erreurs sélectionnée, il va te demander si tu veut sauvegarder clique sur non, puis clique sur corriger toutes les erreurs sélectionnée, OK.
Puis fait une défragmentation :
Bye
C'est Ok
Supprime :
- Menu Démarrer,
- Tous les programmes,
- Accessoires,
- Outils système,
- Défragmenteur de disque,
- Clique sur défragmenter (si tu as plusieurs disques durs fait cette opération pour chacun des disques).
- Propriétés,
- Décochez :
- Appliquer les modifications à D:\et à tous les sous-dossiers et fichiers, si un message d'erreur apparaît cliquer sur Ignorer. Laissez faire.
Bye
- 53 Vues
Dernier message par latoupeum
- 10 Réponses
- 121 Vues
Dernier message par guy85
- 38 Vues
- 47 Vues
- 69 Vues
