Installe la dernière version de Java voir : http://www.java.com/fr/download/installed.jsp
Et suis ce tuto.
Poste le log de JavaRA
problème pour charger adobe flash player 9 résolu
Re: problème pour charger adobe flash player 9
J'ai installé java
Poste le log de JavaRA: comment je fais?
JavaRa est le programme du tuto que je t'ai donné.
Le log se trouve dans C:\ sous le nom de JavaRa.log ou JavaRa.txt
Pfffou ça commence à chauffer dur, mais bon voila le log:
JavaRa 1.11 Removal Log.
Report follows after line.
The JavaRa removal process was started on Sun Nov 09 15:18:13 2008
Found and removed: C:\Program Files\Java\jre1.5.0_05
Found and removed: C:\Program Files\Java\jre1.6.0_07
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\JavaWebStart.isInstalled.1.5.0.0
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F842331866D117AB7000B0D510005
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0003-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0004-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.5.0_05\
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1_02
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1_03
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1_04
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.2
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.2.0_01
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0000-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBB}
Finished reporting.
Skytech a écrit :Salut,
Et si tu installes la version proposé par le site ?
Le site me dirige vers le site d'adobe qui me propose Flash player 10
Ou peut-on charger la dernière version de flash player 9?
Télécharge HijackThis de TrendMicro sur ton Bureau
Sa règlerais pas le problème, et de toute façon je sais pas tu peux trouver ça.sudiste45 a écrit :Ou peut-on charger la dernière version de flash player 9?
- Procède à son installation.
- Une fois l'installation achevée, lance le via son icone sur le bureau ou bien via Démarrer>Tout les Programmes>HijackThis>Hijackthis
- Clique sur "Do a system scan and save a logfile".
- Le rapport s'affiche dans le bloc-note à présent.
- Copie colle son contenu dans ton prochain message sur le forum.
Hello
Ci joint rapport Hijack:
Scan saved at 23:58:17, on 09/11/2008
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16735)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\ZoneLabs\vsmon.exe
C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
C:\Program Files\Fichiers communs\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
C:\Program Files\Bonjour\mDNSResponder.exe
C:\Program Files\Fichiers communs\LightScribe\LSSrvc.exe
C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
C:\WINDOWS\Explorer.EXE
C:\windows\system\hpsysdrv.exe
C:\Program Files\ATI Technologies\ATI.ACE\cli.exe
C:\HP\KBD\KBD.EXE
C:\Program Files\HP\HP Software Update\HPwuSchd2.exe
C:\Program Files\BillP Studios\WinPatrol\winpatrol.exe
C:\WINDOWS\system32\wuauclt.exe
C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATIAIE.EXE
C:\PROGRA~1\MESSAG~1\StartMessager.exe
C:\PROGRA~1\Wanadoo\CnxMon.exe
C:\PROGRA~1\Wanadoo\TaskbarIcon.exe
C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe
C:\Program Files\Thomson\SpeedTouch USB\Dragdiag.exe
C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
C:\Program Files\Webroot\Spy Sweeper\SpySweeperUI.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\Program Files\Secunia\PSI (RC4)\psi.exe
C:\PROGRA~1\Wanadoo\EspaceWanadoo.exe
C:\PROGRA~1\Wanadoo\ComComp.exe
C:\PROGRA~1\Wanadoo\Watch.exe
C:\Program Files\Webroot\Spy Sweeper\SSU.EXE
C:\WINDOWS\system32\wscntfy.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.wanadoo.fr/go/page_recherche/
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.wanadoo.fr
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Wanadoo
R3 - URLSearchHook: Search Class - {08C06D61-F1F3-4799-86F8-BE1A89362C85} - C:\PROGRA~1\Wanadoo\SEARCH~1.DLL
R3 - URLSearchHook: Yahoo! Toolbar avec bloqueur de fenêtres pop-up - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O2 - BHO: EpsonToolBandKicker Class - {E99421FB-68DD-40F0-B4AC-B7027CAE2F1A} - C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll
O3 - Toolbar: EPSON Web-To-Page - {EE5D279F-081B-4404-994D-C6B60AAEBA6D} - C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll
O4 - HKLM\..\Run: [hpsysdrv] "c:\windows\system\hpsysdrv.exe"
O4 - HKLM\..\Run: [ATICCC] "C:\Program Files\ATI Technologies\ATI.ACE\cli.exe" runtime
O4 - HKLM\..\Run: [HPHUPD08] "c:\Program Files\HP\Digital Imaging\{33D6CC28-9F75-4d1b-A11D-98895B3A3729}\hphupd08.exe"
O4 - HKLM\..\Run: [KBD] "C:\HP\KBD\KBD.EXE"
O4 - HKLM\..\Run: [Recguard] "C:\WINDOWS\SMINST\RECGUARD.EXE"
O4 - HKLM\..\Run: [PS2] "C:\WINDOWS\system32\ps2.exe"
O4 - HKLM\..\Run: [HP Software Update] "C:\Program Files\HP\HP Software Update\HPwuSchd2.exe"
O4 - HKLM\..\Run: [WinPatrol] "C:\Program Files\BillP Studios\WinPatrol\winpatrol.exe"
O4 - HKLM\..\Run: [EPSON Stylus Photo R220 Series] "C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATIAIE.EXE" /P30 "EPSON Stylus Photo R220 Series" /O6 "USB001" /M "Stylus Photo R220"
O4 - HKLM\..\Run: [MessagerStarter Wanadoo] "C:\PROGRA~1\MESSAG~1\StartMessager.exe" Messager Wanadoo
O4 - HKLM\..\Run: [WooCnxMon] "C:\PROGRA~1\Wanadoo\CnxMon.exe"
O4 - HKLM\..\Run: [WOOWATCH] "C:\PROGRA~1\Wanadoo\Watch.exe"
O4 - HKLM\..\Run: [WOOTASKBARICON] "C:\PROGRA~1\Wanadoo\TaskbarIcon.exe"
O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe" /min
O4 - HKLM\..\Run: [SpeedTouch USB Diagnostics] "C:\Program Files\Thomson\SpeedTouch USB\Dragdiag.exe" /icon
O4 - HKLM\..\Run: [ZoneAlarm Client] "C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe"
O4 - HKLM\..\Run: [SpySweeper] "C:\Program Files\Webroot\Spy Sweeper\SpySweeperUI.exe" /startintray
O4 - HKCU\..\Run: [ctfmon.exe] "C:\WINDOWS\system32\ctfmon.exe"
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-18\..\RunOnce: [^SetupICWDesktop] (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [^SetupICWDesktop] (User 'Default user')
O4 - .DEFAULT User Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'Default user')
O4 - Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE
O4 - Startup: Secunia PSI (RC4).lnk = C:\Program Files\Secunia\PSI (RC4)\psi.exe
O4 - Global Startup: Barre d'état système d'ATI CATALYST.lnk = C:\Program Files\ATI Technologies\ATI.ACE\CLI.exe
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O8 - Extra context menu item: &Traduire à partir de l'anglais - res://C:\Program Files\Google\GoogleToolbar1.dll/cmwordtrans.html
O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office10\EXCEL.EXE/3000
O8 - Extra context menu item: Pages liées - res://C:\Program Files\Google\GoogleToolbar1.dll/cmbacklinks.html
O8 - Extra context menu item: Pages similaires - res://C:\Program Files\Google\GoogleToolbar1.dll/cmsimilar.html
O8 - Extra context menu item: Recherche &Google - res://C:\Program Files\Google\GoogleToolbar1.dll/cmsearch.html
O8 - Extra context menu item: Version de la page actuelle disponible dans le cache Google - res://C:\Program Files\Google\GoogleToolbar1.dll/cmcache.html
O9 - Extra button: Aide à la connexion - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O9 - Extra 'Tools' menuitem: Aide à la connexion - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class) - C:\Program Files\Yahoo!\Common\yinsthelper.dll
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://www.update.microsoft.com/microso ... 6135950781
O16 - DPF: {CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7} (get_atlcom Class) - http://www.adobe.com/products/acrobat/nos/gp.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} - https://fpdownload.macromedia.com/get/s ... wflash.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{12F0BEE5-FB23-420C-B3D5-1AE614E5A6CF}: NameServer = 81.253.149.1 80.10.246.3
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Fichiers communs\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: AntiVir PersonalEdition Classic Scheduler (AntiVirScheduler) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
O23 - Service: AntiVir PersonalEdition Classic Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Fichiers communs\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: Service Bonjour (Bonjour Service) - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Fichiers communs\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Fichiers communs\LightScribe\LSSrvc.exe
O23 - Service: Ma-Config Service (maconfservice) - CybelSoft - C:\Program Files\ma-config.com\maconfservice.exe
O23 - Service: TrueVector Internet Monitor (vsmon) - Zone Labs, LLC - C:\WINDOWS\system32\ZoneLabs\vsmon.exe
O23 - Service: Moteur Webroot Spy Sweeper (WebrootSpySweeperService) - Webroot Software, Inc. (www.webroot.com) - C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
End of file - 9251 bytes
Bonne nuit, A+
Boot mode: Normal
Running processes:
C:\HP\KBD\KBD.EXE
Bonne nuit, A+
On continue ce soir ou demain.
Ce soir je suis là et demain aussi. A ta dispo et encore merci de ton aide.
Désinstalle via ajout\suppression de programmes si tu trouve :
Yahoo! Companion
Yahoo! Toolbar
EPSON Web-To-Page
(C'est une toolbar inutile puisque il y a déjà un bouton pour imprimer sur IE)
Désinstalle Bonjour avec Revo Unistaller,
Une fois que Revo Uinstaller est installé,
Ferme toutes tes applications (Navigateur, Lecteur audio\video, ...)
Ouvre Revo, cherche Bonjour,
Clique sur Désinstaller, Oui, coche Avancé, Suivant,
Dans la fenêtre qui s'ouvre clique sur la corbeille pleine (Supprimer), Oui, Terminer,
Dans la fenêtre de désinstallation de Revo, clique sur suivant, puis encore suivant,
Patiente un peu puis une fois le scan terminé, clique sur Sélectionner tout, suivant, Oui, Fin.
* Menu Démarrer, clique sur exécuter
* Tape cmd et valide avec ok
* Dans l'invite qui s'ouvre, copie et colle cette ligne
sc stop gusvc
Si un message d'erreur s'affiche, poursuit quand même
* Valide avec OK
* Copie-colle maintenant ça dans la fenêtre:
sc delete gusvc
* Valide avec OK
Si tu n'as plus de produits Yahoo supprime :
Si il te reste des produits Yahoo supprime uniquement ça :
Supprime si tu n'as plus de produits Google :
Si il te restes des produits Google supprime uniquement :
Ensuite reposte un log Hijackthis.
Yahoo! Companion
Yahoo! Toolbar
EPSON Web-To-Page
sc stop gusvc
* Valide avec OK
sc delete gusvc
* Valide avec OK
sc stop gusvc
J'ai une fenetre noire qui s'ouvre avec une seule ligne:
C:/Documents and settings/Cricri>
Je rajoute sc stop gusvc au bout de cette ligne?
J'ai pas de bouton OK pour valider. Je pense que je fais pas la bonne manoeuvre??
sc stop gusvc
Tu valides avec entrée. Et oui, tu tapes la commande après cricri>
j'espère que j'ai tout bien fait
. Ci joint le nouveau log HiJack
Scan saved at 21:44:35, on 10/11/2008
Boot mode: Normal
Running processes:
C:\HP\KBD\KBD.EXE
R3 - URLSearchHook: Yahoo! Toolbar avec bloqueur de fenêtres pop-up - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
O4 - HKLM\..\Run: [SpySweeper] C:\Program Files\Webroot\Spy Sweeper\SpySweeperUI.exe /startintray
End of file - 8576 bytes
Boot mode: Normal
Running processes:
C:\HP\KBD\KBD.EXE
Tu as suivi les indications correctement
(Merci à Grimpo)
Créé un point de restauration.
(Démarrer, tous les programmes, accessoires, outils système, restauration du système.)
Puis :
* Clique sur le Menu Démarrer puis panneau de configuration
* Double clique sur ajouter supprimer des programmes
* Clique sur Ajouter/supprimer des composants windows
* Décoche si tu t'en sert pas : MSN Explorer, Windows Messenger
* Clique sur suivant, laisse faire, redémarre et reposte un log Hijackthis.
Remarque : Windows Messenger ou MSN Explorer n'ont rien à voir avec Windows Live Messenger
Panneau de configuration >>> Options régionales et linguistiques >>> Langues >>> Détails >>> Avancé >>> Cocher la case "Arrêtez les services de texte avancés"
Installe le SP3 de XP via Windows Udapte.
(Sa marche qu'avec Internet Explorer.)
Avant de l'installer à lire
(Merci à Grimpo)
Puis :
Erreur Code 31 "Windows ne peut pas charger les pilotes" dans Windows 10
par RATATOUILLE » » dans Windows : Résoudre les problèmes - 1 Réponses
- 65 Vues
- 23 Réponses
- 779 Vues
- 1778 Vues
ADOBE l'IA et les nouvelles conditions de services
par Parisien_entraide » » dans Tutoriels & Ressources - 0 Réponses
- 339 Vues
🛡️ Google GEMINI 2.0 Flash le tueur de photoshop ?
- 26 Vues
