Internet sous ubuntu studio ? (En cours)
Modérateur : Mods GNU/Linux
captnfab
Re: ubuntu studio
par captnfab »
bon, j'espérais avoir un peu plus d'info que ça de ces commandes…
Du coup, va falloir faire un peu plus bourrin :
dmesg | tail -n 50
Juste après le démarrage de l'ordi.
Ça en fait une tartine, mais j'espère avoir plus d'infos comme ça.
Kandi
Re: ubuntu studio
par Kandi »
:~$ sudo ifconfig wmaster0 up
[sudo]
SIOCSIFFLAGS: Opération non supportée
:~$ dmesg | tail -n 50
[ 37.910101] sdhci:slot0: Will use DMA mode even though HW doesn't fully claim to support it.
[ 37.912399] mmc0: SDHCI at 0xfeaff400 irq 17 DMA
[ 38.000305] iwl3945: Intel(R) PRO/Wireless 3945ABG/BG Network Connection driver for Linux, 1.2.0
[ 38.000309] iwl3945: Copyright(c) 2003-2007 Intel Corporation
[ 38.000424] ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 38.000437] PCI: Setting latency timer of device 0000:03:00.0 to 64
[ 38.000454] iwl3945: Detected Intel PRO/Wireless 3945ABG Network Connection
[ 38.778482] ACPI: Battery Slot [BAT0] (battery present)
[ 38.836482] iwl3945: Tunable channels: 13 802.11bg, 23 802.11a channels
[ 38.838398] wmaster0: Selected rate control algorithm 'iwl-3945-rs'
[ 38.880298] ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 38.880309] PCI: Setting latency timer of device 0000:02:00.0 to 64
[ 38.880318] atl1 0000:02:00.0: version 2.0.7
[ 38.947262] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/device:1b/LNXVIDEO:00/input/input8
[ 38.963233] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 39.570521] ACPI: AC Adapter [AC0] (on-line)
[ 39.774917] Linux video capture interface: v2.00
[ 39.945717] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (174f:5a31)
[ 39.989992] usbcore: registered new interface driver uvcvideo
[ 39.989997] USB Video Class driver (v0.1.0)
[ 40.380518] ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 23
[ 40.380554] PCI: Setting latency timer of device 0000:00:1b.0 to 64
[ 40.546354] loop: module loaded
[ 40.605501] lp: driver loaded but no devices found
[ 40.736235] Adding 1421712k swap on /dev/sda7. Priority:-1 extents:1 across:1421712k
[ 41.097443] EXT3 FS on sda6, internal journal
[ 41.883246] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 42.451140] No dock devices found.
[ 43.494042] apm: BIOS not found.
[ 43.610199] ppdev: user-space parallel port driver
[ 43.742178] audit(1223222540.881:2): type=1503 operation="inode_permission" requested_mask="a::" denied_mask="a::" name="/dev/tty" pid=5184 profile="/usr/sbin/cupsd" namespace="default"
[ 45.033323] Bluetooth: Core ver 2.11
[ 45.033466] NET: Registered protocol family 31
[ 45.033467] Bluetooth: HCI device and connection manager initialized
[ 45.033471] Bluetooth: HCI socket layer initialized
[ 45.082293] Bluetooth: L2CAP ver 2.9
[ 45.082297] Bluetooth: L2CAP socket layer initialized
[ 45.157602] Bluetooth: RFCOMM socket layer initialized
[ 45.157618] Bluetooth: RFCOMM TTY layer initialized
[ 45.157622] Bluetooth: RFCOMM ver 1.8
[ 54.610170] NET: Registered protocol family 10
[ 54.610998] lo: Disabled Privacy Extensions
[ 60.749175] CPU0 attaching NULL sched-domain.
[ 60.749185] CPU1 attaching NULL sched-domain.
[ 60.749197] CPU0 attaching sched-domain:
[ 60.749203] domain 0: span 03
[ 60.749206] groups: 01 02
[ 60.749248] CPU1 attaching sched-domain:
[ 60.749251] domain 0: span 03
[ 60.749266] groups: 02 01
voila!
captnfab
Re: ubuntu studio
par captnfab »
Bizarre, le module a l'air de bien se charger, pas d'erreur due à un firmware manquant ou je ne sais quoi. J'ai du manquer quelque chose.
Tu peux me donner les sorties de ces deux commandes stp :
sudo ifconfig
et
sudo ifconfig -a
Kandi
Re: ubuntu studio
par Kandi »
voila :
lo Link encap:Boucle locale
inet adr:127.0.0.1 Masque:255.0.0.0
adr inet6: ::1/128 Scope:Hôte
UP LOOPBACK RUNNING MTU:16436 Metric:1
Packets reçus:3732 erreurs:0 :0 overruns:0 frame:0
TX packets:3732 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:0
Octets reçus:186600 (182.2 KB) Octets transmis:186600 (182.2 KB)
@:~$ sudo ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:22:15:74:7a:1b
BROADCAST MULTICAST MTU:1500 Metric:1
Packets reçus:0 erreurs:0 :0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:1000
Octets reçus:0 (0.0 B) Octets transmis:0 (0.0 B)
mélodie
Re: Internet sous ubuntu studio ? (En cours)
par mélodie »
J'ai édité un peu ton titre, pour le rendre plus conforme *Au règlement*.
Lis un peu des posts et tutos sur le sujet:
http://forum.ubuntu-fr.org/viewtopic.php?id=204360&p=1
http://doc.fedora-fr.org/wiki/Wifi-Inst ... ss_3945ABG
http://www.google.fr/search?hl=fr&sa=X& ... rg&spell=1
Je te recommande de lire les liens sous ma signature, ça t'aidera à gagner du temps quand tu postes. PDT_019
(Par exemple, commencer par donner les caractéristiques de ton ordinateur, à défaut d'en connaître tous les composants).
Texte culte
Kandi
par Kandi »
ok jvais allez voir ca !
Kandi
par Kandi »
donc apparement il faut que je telecharge un pilote linux pour ma carte wifi (intel iwl 3945),ce qui est fait mais où je dois collé le fichier ?
captnfab
par captnfab »
Yo Kandi,
http://doc.ubuntu-fr.org/asus_a6jm a écrit : WiFi
Le chipset WiFi Intel Pro Wireless 3945 nécessite un firmware non-libre, et qui se trouve donc dans les paquets linux-restricted-modules. Si votre interface WiFi n'est pas ou plus détectée, assurez-vous que le paquet correspondant à votre noyau actuel est installé, puis rechargez le module ipw3945. Cela peut se faire avec les commandes suivantes :
sudo apt-get install linux-restricted-modules-$(uname -r)
sudo modprobe -r ipw3945
sudo modprobe ipw3945
Et cela télécharge / place au bon endroit les « drivers » nécessaires tout seul.
Kandi
par Kandi »
ok mais moi ma carte wifi n'est pas une ipw mais iwl
captnfab
par captnfab »
Essaye déjà avec ipw, si ça ne marche pas, regarde avec iwl.
Si j'ai bien tout suivi, les deux modules sont tous les deux des drivers pour ta carte WiFi, iwl étant censé remplacer ipw à terme.
Kandi
par Kandi »
ne marche pas , il me mette paquet introuvable et unable to host ...
captnfab
par captnfab »
Je peux avoir le message d'erreur exact ?
Kandi
par Kandi »
[email protected]:~$ sudo apt-get install linux-restricted-module-$(uname -r)
sudo: unable to resolve host toma
[sudo] password for thomas:
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
E: Impossible de trouver le paquet linux-restricted-module-2.6.24-19-rt
[email protected]:~$ sudo rmmod iwp3945
ERROR: Module iwp3945 does not exist in /proc/modules
[email protected]:~$ sudo rmmod iwl3945
[email protected]:~$ sudo modprobe iwp3945
FATAL: Module iwp3945 not found.
[email protected]:~$ sudo modprobe iwl3945
sinon ya peut etre la solution la dessus mais je trouve pas son fichier win32
http://mige.blogspot.com/search/label/3945
captnfab
par captnfab »
Bon, déjà, ton message « sudo: unable to resolve host toma » n'est pas normal, on va le corriger dessuite.
tape
sudo gedit /etc/hosts
et ajoute la ligne
127.0.0.1 toma
Ensuite, regarde le contenu du fichier /etc/apt/sources.list
Il faut que la branche « restricted » soit présente (et non commentée)
Une fois ceci vérifié et une connexion internet activée (par câble ça doit marcher) :
sudo apt-get update
Kandi
par Kandi »
[email protected]:~$ sudo gedit /etc/hosts
[email protected]:~$ more /etc/apt/sources.list
# deb cdrom:[Ubuntu-Studio 8.04.1 _Hardy Heron_ - Release i386 (20080701)]/ hard
y main multiverse restricted universe
#deb cdrom:[Ubuntu-Studio 8.04.1 _Hardy Heron_ - Release i386 (20080701)]/ hardy
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://fr.archive.ubuntu.com/ubuntu/ hardy main restricted
deb-src http://fr.archive.ubuntu.com/ubuntu/ hardy main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://fr.archive.ubuntu.com/ubuntu/ hardy-updates main restricted
deb-src http://fr.archive.ubuntu.com/ubuntu/ hardy-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://fr.archive.ubuntu.com/ubuntu/ hardy universe
deb-src http://fr.archive.ubuntu.com/ubuntu/ hardy universe
deb http://fr.archive.ubuntu.com/ubuntu/ hardy-updates universe
deb-src http://fr.archive.ubuntu.com/ubuntu/ hardy-updates universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://fr.archive.ubuntu.com/ubuntu/ hardy multiverse
deb-src http://fr.archive.ubuntu.com/ubuntu/ hardy multiverse
deb http://fr.archive.ubuntu.com/ubuntu/ hardy-updates multiverse
deb-src http://fr.archive.ubuntu.com/ubuntu/ hardy-updates multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://fr.archive.ubuntu.com/ubuntu/ hardy-backports main restricted unive
rse multiverse
# deb-src http://fr.archive.ubuntu.com/ubuntu/ hardy-backports main restricted u
niverse multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository. This software is not part of Ubuntu, but is
## offered by Canonical and the respective vendors as a service to Ubuntu
## users.
# deb http://archive.canonical.com/ubuntu hardy partner
# deb-src http://archive.canonical.com/ubuntu hardy partner
# Line commented out by installer because it failed to verify:
#deb http://security.ubuntu.com/ubuntu hardy-security main restricted
#deb-src http://security.ubuntu.com/ubuntu hardy-security main restricted
#deb http://security.ubuntu.com/ubuntu hardy-security universe
#deb-src http://security.ubuntu.com/ubuntu hardy-security universe
#deb http://security.ubuntu.com/ubuntu hardy-security multiverse
#deb-src http://security.ubuntu.com/ubuntu hardy-security multiverse
[email protected]:~$ grep restricted /etc/apt/sources.list
# deb cdrom:[Ubuntu-Studio 8.04.1 _Hardy Heron_ - Release i386 (20080701)]/ hardy main multiverse restricted universe
#deb cdrom:[Ubuntu-Studio 8.04.1 _Hardy Heron_ - Release i386 (20080701)]/ hardy main multiverse restricted universe
# deb http://fr.archive.ubuntu.com/ubuntu/ hardy-backports main restricted universe multiverse
# deb-src http://fr.archive.ubuntu.com/ubuntu/ hardy-backports main restricted universe multiverse
apres le apt get ... ne marche pas
